JD 50 CARB REBUILD KIT
Bill
10-05-2003 16:14:41
Just curious if anyone knows of a carb kit available that would by chance include a new load adjustment valve. This tractor doesn't want to run under a load, so I thought I would try to clean it out and throw a kit in it. However, it appears that a previous owner of this tractor somehow destroyed the first few threads on the current valve.
I picked up a rebuild kit from the local farm store, but it doesn't include the valve, or the gaskets that go on each end of the carb (next to the air intake & manifold).
I'll check with my JD dealer tomorrow on the valve availability, but wanted to see if anyone else had any input first.
Thanks.
ChuckW
10-05-2003 17:06:07
 Re: JD 50 CARB REBUILD KIT in reply to Bill, 10-05-2003 16:14:41
that little valve is about $35.00 from JD and has special threads. The reason the threads get messed up is in removing, people keep turning and it is held in place by the o ring and the threads are then worn. I always take small vise grips or wire pliers and when removing to be sure the thread clear at the end and then pull the plub out. Also don't over tighten as the little end will be damaged. Not sure if Robert's carbs carries these or not.
Earl S.
10-05-2003 18:11:47
 Re: Re: JD 50 CARB REBUILD KIT in reply to ChuckW, 10-05-2003 17:06:07
$52.14 from Roberts,he gets them from Deere. Deere is the only source.
