Choking Model M
Fritz Campbell
10-05-2003 05:51:10
My wife and I were enjoying the tractor pull at the NAMA show in Centre Hall, PA over Labor Day weekend and I watched a fellow with a nice looking Model M reach down and pull the choke out when he was under load and his M started cutting out. I have had the same problem with mine and when running it last night, tried it and it leveled it right out. What is the problem that adding choke corrects this cutting out under load problem? I've wrestled with this problem since I've had mine. Thanks to all for the advice.
Wayne in Tn.
10-05-2003 09:01:38
 Re: Choking Model M in reply to Fritz Campbell, 10-05-2003 05:51:10
Fritz, I would say you need to open up the load needle some, on the bottom of the carb. On these Dubuques, if you are just going to be putting around, you can run with the needle (in) to help stop the black smoking, but under a load, they will have to be opened up some.
