I can't believe that after 22 years of faithful service my garden tiller won't start anymore. It popped off like it wanted to work but died after a burst. Then it just made weak popping sounds back thorough the carb.I put a tune up kit in it and a new flywheel key which made the spark hot and the plug snap when checked against the block. But no startup and the same occasional weak pop out the carb. I checked the compression and it was virtally nothing. I noticed the head gasget had been leaking for a long time so I removed the head for a true up and new gasget. Here comes the question. I checked the valve clearance (both seats are shiny and not burned) and here are the results. Exhaust .009 Intake. It maintains .006 on the exhaust stroke. After the intake closes at the bottom of the intake stroke and the piston starts up the valve remains unseated slightly due to no clearance for about 3/4 of the compression stroke. For the last part of the compression stroke the intake closes and is at the usual .006 to .007 at top dead center on the compression stroke. I vaguely remember from my younger years that some of the Briggs used the type of valve action described above on the intake to promote easy spin starting. I don't have a tech book on this ole 5 hp and a trip to the library would take another half day. Danged if I know, maybe fixing the head gasget problem is all that is needed. Thanks for any input in advance on how to set up this particular valve train clearance.
