620 3 point return spring
Mike
10-04-2003 05:33:05
I just put a 620 through a total restoration and I am missing the big spring on the left side of the 3 point hitch, can anybody give and idea what I can use, or if they have one for a decent price, it seems that Jd can't get a new one and , could I just use a big spring from tractor supply?
Mr. Green
10-04-2003 10:27:24
 Re: 620 3 point return spring in reply to Mike, 10-04-2003 05:33:05
You don't need the spring. It will worl without it. If you can't get the right spring i would not put one on at all, because it just will not look right. Try finding a good used spring. The first place i would try is Dengler vintage tractor parts. Middletown, Ohio
Phone 513-423-4000 or 513-423-0706
JDVan
10-04-2003 10:23:51
If i recall prperly the 620 return spring is the same one that is used on the 520/530 and 630. Not sure about the 720/730. However, if you do find a original JD spring you will notice in the parts book that the 620/630 requires an additional S hook to lengthen the connect points a bit. The S hook isn't available from JD anymore either. I made one from a standard hardware S hook.
You might try some major antique tractor salvage yards to find a used one. Have you done a nationwide JD dealer search to see if any JD dealer still has a NOS one in stock? Also try Greg Stephen at Stephen Equipment in Franktown, CO. He has a large supply of 2 Cylinder NOS parts. Also a current JD dealer.
www.oldtractorcompany.com
