D model john deer magneto operation
Thomas Donadio
10-03-2003 20:35:53
I wanted to give the specifics on the magneto and on the year of the tractor. the magneto is a wico AP the tractor is a D model john deer 1946 multi distillate maybe this will give you all that replied to my first inquirey into my magneto question some better idea of what i have. thanks Thomas Donadio
Glen in TX
10-04-2003 17:47:50
 Re: D model john deer magneto operation in reply to Thomas Donadio, 10-03-2003 20:35:53
Duane is right. I have never seen anything that would show a D coming out with the Wico AP or seen a D with one on it. The AP was used for a while on the A,AR,AO,B,BR,&BO. Your '46 should have came out with the Edison Splitdorf CD model. Unless they ran out and had some AP mags out and put them on that day when they built yours? The CD does only fire on compression and works well on a 1947 D we have tractor pulled with.
Duane Larson
10-03-2003 21:25:20
Thomas,
FWIW, I do not believe the D came from the factory with a Wico AP magneto. While there was a lot of swapping between the Edison Splitdorf CD and Wico C477B between s/n 152707 and 155999, I believe your D came with an Edison Splitdorf CD spec 0010. The E-S magneto has a gear reduction, so it only sparks at the end of the compression stroke, and not during the exhaust stroke as do most Wico magnetos.
