JD 2020 Exhaust
David
10-03-2003 17:17:22
I just bought a 67 2020 gas. It has a vertical exhaust which I'd like to change to horizontal. Along with new gaskets, do I need to do anything other than locate the correct intake/exhaust manifold, bolt it on and attach a new exhaust/muffler/tailpipe and reattach the old carb? Anybody out there wanna trade manifolds?? Thanks!
Another David
10-04-2003 02:28:57
 Re: JD 2020 Exhaust in reply to David, 10-03-2003 17:17:22
I'm sure you have your reasons for wanting horizontal exhaust but I'll share my story. I bought a 2030 diesel with horizontal exhaust under the left floor board and hated the tractor. Any time it was running but not moving as in hooking up implements it would gas you. I had a muffler shop bend a goose neck and reattached the same muffler in the vertical position. It's like a different tractor now and I love it.
Ed in IN
10-03-2003 18:28:47
You will also need a new hood, since the vertical muffler goes through it. Plan on putting some type of heat shield above the muffler so it won't cook your left foot. I've had a 2020 gas with horizontal muffler for 16 years and that is my only complaint, other than having to get off and pick up my cap from getting knocked off by low hanging limbs.
JDBert
05-15-2006 08:55:33
 Re: 35 B JD Hand Crank Problems in reply to Jak, 05-15-2006 06:46:45
Heres a trick my grandpa showed me and it always works for me on my 36'
Start by bringing it up on compression- turn your choke on full and your throttle all the way back- then roll it BACKWARDS once or twice- you should here it take a big glup of fuel. bring it back up on compression- turn your choke off and give it about 1/2 throttle. Pull it through. Mine usually starts on the first pull maybe 2nd-
