730D update
MIKE HANLEY
10-03-2003 12:45:47
The G E P in the ovel stamped inside the pistons stands for GOULD ENGINE PRODUCTS. They were bought out by IMPERIAL CLEVITE in 1978 and at that time the trademake inside the piston was changed to the IMPERIAL CLEVITE trade mark. This from the enginering dept at CLEVITE. The 730 with .090 oversize pistons that had not been made in years in an overhauled engine,,,well if two and two still makes four,,,was not bored out 1200 hours ago. It was just honded and the old pistons put back in. Leading us to belive the engine cylinders were never checked for being out round. This is also leading us to belive that new valve sets were not put in. Just ground. The valves are too far into the head to match the wear. So how many engines are being overhauled in the machine shed and the cylnders are not being cheked for out of round? I don't know anyone outside a machine shop or a well equipt dealer that has the proper gages to check this. Food for thought here. Still trying to find the recieces and the work order. Still working on other info and what will let you know what we will be putting into the engine. Right now we are leaning to sliveing the block and going back to STD JOHN DEERE with JD parts.
into the engine.
buickanddeere
10-05-2003 11:47:38
 Re: 730D update in reply to MIKE HANLEY, 10-03-2003 12:45:47
Amazing isn't the number of people who will swear an engine is rebuilt. With just a head gasket,rings,grinding the valves/seats. Leaving the worn valve guides in place and using only gasket goo on all other mating surfaces. Found a mess like that on the 80. They didn't even touch the injectors except for wrecking the tips by likly setting the head face down on the bench.
