850 w/75 loader hydraulics quit in the cold?
SteveB
01-20-2004 20:54:18
What would cause my hydralics to not funtion? I started my tractor up last night the temp is around 15dg. Everything was funtioning fine last month. Now my loader or rockshaft do not move? I could here the relief valve and the bucket would move about an inch than nothing. is it possible for hydro systems to freeze up? This doesnt happen with my other equip. I checked fluid level and she was low so I added, but that made no difference? All valves are open, the tractor worked flawlessly when I tarped it last month.
leon
01-22-2004 03:34:11
 Re: 850 w/75 loader hydraulics quit in the cold? in reply to SteveB, 01-20-2004 20:54:18
I believe, before I tore the thing apart, I'd either warm it up to above freezing in a shed or garage or wait 'till warmer weather and see if it again works OK. I'm wondering if there just might be an accumulation of water in the transmission that plugged up either the oil pick-up screen or filter. Maybe somehow, water just accumulated in a low spot in a hydraulic line. How long since the transmission fluid was changed? Especially if it's been several hundred hours of operation or several calendar years and warming it up makes it work again, I'd try changing the transmission oil and see if the problem goes away. Of course a filter change and a cleaning of the pick-up screen (assuming it has both) is required too at oil change time.
Mike M
01-21-2004 07:01:12
I had a neighbor that has a 850 and his hyd. pump
shaft key broke. It is metric and can be ordered from a dealer it is easy to pull the pump off and check.His is an early one the later ones may be differant. He had quick couplers on the hoses and they came unhooked while brushhogging causeing a surge of pressure.
