Air filter stack
Bill
10-03-2003 06:29:35
I am try to gather some opinions on whether it will hurt to take a couple of inches off the air intake stake on my JD tractor so it will fit in a shed. I would like to park my tractor inside and away for the winter, but the building I have available only has one big door and the air intake stack is about 2 to 3 inches too tall. I am wondering if a person can safely cut those few inches off the stack or is it going to hurt something.
thanks
BIll
37D
10-03-2003 18:51:30
 Re: Air filter stack in reply to Bill, 10-03-2003 06:29:35
If it,s just going in for the winter, I'd let air out of the tires, as someone else already suggested, that way you won't ruin a perfectly good air stack. If it's unstyled, try to find one from an AR (assuming it's an A you're referring to.)
CLW
10-03-2003 09:07:20
Bill, I know this is not what you ask, but my A is to tall for one garage I have. Since I only put it in that garage once or twice a year I can let enough air out of the front tires to get it down the two inches I need.
CLW
John T
10-03-2003 08:40:30
Good Morning Bill, you asked for opinions, so its my opinion that shortening the air stack height will cause no problems whatsoever. In fact, in theory at least, any reduction in resistance to air flow into the engine would improve performance. However, what youre doing is so slight, it wouldnt even be measureable. As you know, blowers are used to actually force air into an engine under more than atmospheric pressure and high performance low air flow resistance air filters "supposedly" improve performance.
Best Wishes n God Bless
John T
DP
10-03-2003 08:00:10
That will not affect your tractors performance. One thing to be aware of though, is if you are doing this to a working tractor that you pull hard, the heat from the muffler will distort the plastic bowl. My uncles did this to the 620 I now own.
Clooney
10-03-2003 06:57:30
Bill, no problem. In fact on a lot of the old Deere's, Deere offered a shorter muffler & intake stack for low barn door clearance..
~I have such a set-up on one of my unstyled A's so if you are working on an US A let me know & will give you the correct muffler & air intake height for the factory short muffler & air intake..
