620 carb leak
Mike
10-02-2003 21:13:33
I have a 620 carb that leaks out the load stem, I took it apart and it has an o ring on it, it looks like two could fit on it, what is the best fix here, thanks guys.
Duane Larson
10-03-2003 05:20:06
 Re: 620 carb leak in reply to Mike , 10-02-2003 21:13:33
Mike,
If you do replace the bowl nut gasket, remember it goes on before the bowl goes on, not between the bowl and nut (although it doesn't hurt to put one there also).
Clooney
10-03-2003 03:15:38
Mike, first make sure the bowl nut isn't leaking at the nut, gasket, or bowl interface [CAUTION: don't over-tighten the bowl nut or you risk a very costly carb stem repair].
~If the actual leak is at that load screw to carb stem try a new "O" ring, yours is probably worn, nicked, or dried out..
mike
10-03-2003 20:54:29
 Re: Re: 620 carb leak in reply to Clooney , 10-03-2003 03:15:38
thanks guys , will check it in the morning.
