D model john deer
Thomas F Donadi
10-02-2003 19:15:51
does anyone know how the magnetos go through the cycle of producing sparks, how many revolutions to make a spark on a d model john deer?
Thanks John T and Clooney
10-03-2003 07:36:01
 Re: D model john deer in reply to Thomas F Donadio, 10-02-2003 19:15:51
Special thanks to John T and Clooney again. Their respective answers to this question provides good accurate honest information to all of us JD owners who are too shy to ask these questions ourselves. John T and Clooney's answers to this questions makes this site worth the money. I look at this site every few days to learn from these experts. I might not need the information immediately, but I probably will in the future. Thanks. Thanks. Thanks. Thanks.
John T
10-03-2003 07:59:05
 Re: Re: D model john deer in reply to Thanks John T and Clooney, 10-03-2003 07:36:01
Youre welcome Thomas, glad we were able to help. I also learn here and appreciate all the fine people who share their knowledge with all of us.
John T
Clooney(magneto operation
10-03-2003 04:51:45
Thomas, it would help to know the year of your "D" & the mag type [not all Deere mags operate the same]� Depending on the year & what�s been substituted over the years your �D� could have any one of the following mags�Eisemann, Dixie, Splitdorf, Edison-Splitdorf, Fairbanks Morse, Wico C, or Wico X [XH] with a few different sub models in each group.
~In any case the mags mentioned above pretty well operate the same [at least in principle]. Some spark twice every revolution, some only spark twice on every other revolution.
~A mag [magneto] is basically a distributor with a built in generator to self-power the magneto coil when the internal shaft(s) are rotated.
~Some magnetos such as the later Wico C & X spin at crankshaft speed & produce a spark EVERY TIME each piston comes to TDC [even on the exhaust stroke], others like most of the others mentioned above only produce a spark on each compression stroke due to an internal gear reduction to slow the mag points shaft to � engine speed].
~Most magneto�s spin too slowly at engine starting speeds to produce a usable spark [especially on the hand start models] so some type of starting aid has to be incorporated in the mag to enhance the spark at starting speeds. Most just use a set of centrifugally operated arms that catch a stop ring & hold the internal rotating magnet until a spring winds up, then lets the shaft go at the correct time to unwind the spring & allow the internal generator to spin fast enough to produce enough power to power the internal coil. Others like on the early �D�s� have an arming lever that must be moved into engagement to manually force the mag to go into the starting retard mode..
~Most mags used on the late �D�s� have a fixed timing advance with just 2 settings,,, fully advanced for normal operation [that is usually set to come in at about 250 RPM�s],, & retarded [lag] for starting & that usually automatically comes into play at below 250 RPM�s�.The early �D�s� had a true variable timing & used a manual spark timing controlled by the tractor operator [the short lever next to the hand throttle].
~Some magnetos use an internally rotating magnet [like the later Wico�s] to produce the power to run the mag & others use a fixed horseshoe magnet on the outside of the mag & rotate a winding or lamination inside that magnet to produce the necessary power. [basically, NOT ALL magnetos spin the magnet].
~Due to the low [momentary] power produced by the generator in a mag the peak power produced by the rotating magneto generator must be timed perfectly with the points opening to allow the mag to produce a strong usable spark. Some of the early mags are very critical to correct internal rotating parts timing.
~One advantage of a mag is it usually produces more power the faster it turns so the spark gets better as the engine speed increases.
~To answer you question on..� how many revolutions to make a spark on a D model john Deer?��.That depends on the mag you have� Most of the later Wico equipped �D�s� produce a spark on each � revolution of the mag [every time it snaps],, some of the earlier mags only produce a spark every other revolution. The early �D� operators manual says to turn the crankshaft until you hear 4 snaps to check for a spark. Remember some of the early �D� mags have to be manually armed to produce a spark at cranking speeds.
~I know this doesn�t explain it all but this in addition to the other posts below will help you to understand the basic magneto operation.
~Post back [or E-Mail] with any questions you have & we will be glad to answer all the questions you have..
[email protected]
Matt
11-02-2003 20:46:55
 Re: Re: D model john deer in reply to Clooney(magneto operation, 10-03-2003 04:51:45
Very interesting,We have a 28 or29 D That has been on our farm since new.It is all there except for the magneto,What Mag belongs on her?We used to turn her over as kids playing with her But unfortunally she is now stuck!Where should i begin?Thanks (And NO shes not for sale)
Kenny
10-03-2003 20:13:54
Excellent info on the magneto operation. I have a Model D with an Edison-Splitdorf and would like to know what the wire terminal on top of the mag is for. There was a 5 foot length of wire connected there when I bought the tractor, but it wasn't terminated at the other end so I removed it.
Duane Larson
10-03-2003 20:36:31
 Re: Re: Re: D model john deer in reply to Kenny, 10-03-2003 20:13:54
Kenny,
The post is to provide a ground in the primary circuit of the magneto. It can be connected to a "stop" switch, as grounding the terminal will remove spark.
John T
10-02-2003 22:36:52
Hi Thomas, On mags that are straight driven via the governor shaft (i.e. not gear reduction drive and may be base or governor mounted) they turn the same RPM as the crankshaft. Their coils fire every 180 degrees of rotation (two fires per revolution) as they have 2 magnets on the rotor, each of which passes by and induces voltage into the coils low voltage primary winding.
When the coil fires the rotor tip is first in line with the left cylinders cap tower and fires that plug, and then 180 degrees later, the tip is in line with the right cylinders cap tower and it (when coil fires) fires that cylinders plug.
The non gear reduction (run at crankshaft RPM)direct drive mags, therefore, produce a spark each 180 degrees, since there's 2 magnets on the rotor and they fire each cylinders plug at TDC on BOTH its compression or exhaust strokes. On the non gear reduction drive mags like the Wico C or XH series and others, if the mag is installed 180 out, a simple plug wire reversal makes her run again. Thats untrue on gear reduction drive mags.
The Model D, like the other 2 cylinder Deeres, fires the left cylinder on its compression power stroke TDC, and then 180 later, fires the right cylinder on its compression TDC. Then theres a long 540 degreee coast cycle before the left cylinder is back up to TDC on compression and the cycle repeats over n over n over hopefully, lol.
At slow cranking speeds, the rotors magnet passes too slowly past the coil to produce any spark, therefore, at less than approx 250 RPM, the mag uses a spring wind and trip mechanism which winds a spring then it releases (mag snaps) and rapidly whirls the rotor past the magnet fast enough to produce a spark to start the tractor. Then at around 250 RPM, the wind and trip are disengaged and the mag runs at straight crank RPM and fires the plugs per the above.
Is that the information you were looking for?? Do you need any more regardign their theory of operation??? If so, post back or e mail me at [email protected] or you can call me at 812-824-4608 and perhaps I can explain it further.
Good Luck n God Bless
John T Nordhoff
Glen in TX
10-02-2003 22:09:15
It will rotate 180 degrees and then another 540 degrees between firing cycles. Some mags will also fire in the exhaust.
