History of the Rollomatic
Bruce L
10-02-2003 14:05:37
Over the years, every once in a while I have heard it said that the rollomatic was a farmer invention. Is this true? Does anyone know the real story? I've always thought it was a very clever idea.
Diesel Don
10-03-2003 08:05:22
 Re: History of the Rollomatic in reply to Bruce L, 10-02-2003 14:05:37
I'd like to have the opportunity to drive my A with Roll-o-Matic and another tractor without it over a plowed field to see the difference. I like watching the fronts on a R-O-M work. It was a neat set up.
Dr.EVIL
10-03-2003 12:02:09
 Re: Re: History of the Rollomatic in reply to Diesel Don, 10-03-2003 08:05:22
Where I always thought they helped the most was when plowing. If the plow plugged and You swung around onto the land to clear the plug, when You dropped back into the furrow the steering wheel didn't jerk so hard like on other tractors. The wheels walked right through easily. Same with rounding off the corners when plowing in circles. Across a plowed field I never saw much difference. For the most part the front wheels carried so little weight on NFE 4010/4020's You were lucky to see tire tracks.
Jack
10-03-2003 09:50:39
We had my 53 G out in the field last weekend using it to pull a big log out to where we could cut it up for firewood.After it was dragged out the wife wanted to drive it to get experience.I watched the front wheels every time she came by and the rol-a-matic was doing some working.It kinda surprised me at how much they do move just going across a field.
Mr. Green
10-03-2003 03:38:24
John Deere started using Roll-O-Matic in 1947.
farmer
10-02-2003 15:23:14
it was invented by Ronnings. A Minnisota farmer. Also invented the Ronnings ensilage harvester for mccormick deering.
RayP(MI)
10-02-2003 17:20:32
 Re: Re: History of the Rollomatic in reply to farmer, 10-02-2003 15:23:14
It is my understanding that the inventor offered the idea to Farmall first, and they rejected it. He then offered it to Deere, and they used it very successfully for many years, believe starting in '48 or '49. (Our '47 Deere didn't have it, we now have a '49 that does.) Maybe someone can set the record straight.
Tim
10-02-2003 18:11:28
 Re: Re: Re: History of the Rollomatic in reply to RayP(MI), 10-02-2003 17:20:32
Ray you are correct it was first offered to International and they rejected it and then he offered it to deere and they excepted it.
Dave
06-07-2004 10:57:42
 Re: Re: Re: Re: History of the Rollomatic in reply to Tim , 10-02-2003 18:11:28
Doing some research on the Rollomatic, and I wonder, do you know the patent number(s) that it was described under?
ah, no
10-02-2003 19:58:58
Ah, they accepted it, but they didn't except it.
Noah
10-03-2003 04:57:27
 Re: Re: Re: Re: Re: History of the Rollomatic in reply to ah, no, 10-02-2003 19:58:58
You would have EXPECTED that Farmall would have ACCEPTED it, EXCEPT that they didn't!
tw
10-03-2003 07:58:49
 Re: Re: Re: Re: Re: Re: History of the Rollomatic in reply to Noah, 10-03-2003 04:57:27
They probably inspected it, before they decided not to accept it, even though they were expected to accept it.
