P.S. to my post above... I am almost certain the point mounting (where the module will attach) will be the same between both Delco distributors. If there happens to be a minor difference, you could probably make it work. I have used quite a number of Pertronics units, sometimes for applications they were not intended for, by drilling new mounting holes, or removing areas on the aluminum base the module is attached to that interfere with something in the particular distributor I'm working with. You can mount a Pertronics unit in just about any distributor you can't get a module for by getting a module for an application with the proper number of cylinders, and then modifying the magnet wheel to fit, and mounting the module in such a way that the magnets pass by it at the level they would in it's proper application. The other issue is rotor phasing. On a shop-made application, I cut away an old distributor cap so I can look inside while it's operating. The sparks from the rotor to the cap wire towers will be visible, and the rotor must be close to the appropriate terminal when the spark occurs. This will actually vary with the centrifugal advance, so you want to set up the mounting of the module so, at low RPM's the spark will occur at the leading edge of the terminal, so that when advance occurs with an increase in RPM's, the spark will not occur too far from the trailing edge of the terminal. This is determined by the mounting location of the Pertronics unit.The magnet wheel can also be modified for a lesser number of cylinders than it was designed for by carefully removing the appropriate magnets. For example, a 4 cylinder unit can be modified for Deere 2 cylinder use by removing every other magnet. In this manner, you can set up an electronic ignition system for nearly any distributor, even if Pertronics doesn't make a kit for your specific distributor.
