1945 John Deere LA
Kevin
10-02-2003 08:31:53
Does anyone know the proper point gapping specs for this model? Thanks.
Kevin
Clooney
10-02-2003 11:24:17
 Re: 1945 John Deere LA in reply to Kevin, 10-02-2003 08:31:53
Kevin, it's .020" [on the high part of the points cam] for a distributor & .015" [on the high part of the cam] for a mag...
~Check the dist/mag center shaft for bushing wear & if there is shaft slop, open the points gap slightly [maybe .001"-.002" more]. If there is a lot of slop pull the dist/mag & repair the problem...
John T
10-02-2003 09:07:34
John, the specs listed here for all Model LA's show a point gap of 0.020 and plugs at 0.025, but I have been known to set both a shade wider, maybe 0.022 on the points and 0.030 on plugs?? Try the recommended and slightly wider gaps and see how the old girl does maybe. For parade or light use, I also like to run a heat range or so hotter plug than called for on some tractors.
Good Luck n God Bless
John T
