'48 AW Special Equipment??
Sam F.
10-01-2003 21:16:54
Just got my production record research back from Two-Cylinder Club. One of the items special equipment is "aa4060". What is this?? Also, came with 11-42 rears and 5:50x16 front tires, does this make it a "AWH"?? Thanks
Dennis
10-02-2003 04:32:54
 Re: '48 AW Special Equipment?? in reply to Sam F., 10-01-2003 21:16:54
Sam,
I cannot help you with the "aa4060" special equipment code, but I can help with your question about your tractor being an 'AWH'. Check the casting # on your rear axle housing. If it is A3271R, then your tractor is a long-axle, high-clearance model which in 1948 would have been referred to as an 'AN' or 'AW' (the 'H' designation was dropped with the beginning of the late-styled production run). The information you received from Two-Cylinder should tell you whether the tractor left the factory with a wide front (AW) or single front (AN). Again, the key to determining whether or not a late-styled 'A' is a high-clearance tractor is the rear axle housing. You should also check the length of your wide front spindles. If they are 19 3/4", then you have the correct 'tall' wide front. Many people believe that a wide front makes a Model A (or Model B, Model 60, Model 50, etc. for that matter) a 'W', but the real determining factor is the special long-axle rear axle housing.
Dennis
Sam F.
10-02-2003 08:28:42
 Re: Re: '48 AW Special Equipment?? in reply to Dennis, 10-02-2003 04:32:54
Dennis: It does have the 19 3/4" front spindles. On the production report it states standard equipment for the "AW", speaking about tire size. I cannot find the rear axle housing casting number. The wheels are in as far as they can go and there is bout 12"-14" of axle on the outside past the hub clamps. I beleive this tractor to be totally original, as nothing, including muffler hole, has been cut. I bought it from a widow woman whose husband had purchased it new. Still want to find out what that "aa4060" special equipment is. ??? Thanks alot SAM
Dennis
10-02-2003 11:35:58
 Re: Re: Re: '48 AW Special Equipment?? in reply to Sam F., 10-02-2003 08:28:42
Sam,
The rear axle casting number should be on the front side of the rear axle housing just behind the brake pulley (on my 'BW' it is on the belt pulley side and I believe that is where you will find it on your tractor). As for the rear axles, if the centering hole is still visible at the end of the axle they haven't been cut. Is your tractor a gasoline or all-fuel (distillate)? Congratulations, you have a relatively scarce tractor. The fact that it is a one-owner and you might be able to put together some history makes it even more attractive in my eyes. I am confident that someone on this board will be able to tell you what the "aa4060" code is. If not, a call to Two-Cylinder as a follow up to their research would be in order.
Good luck!
Dennis
Sam F.
10-02-2003 12:31:11
 Re: Re: Re: Re: '48 AW Special Equipment?? in reply to Dennis, 10-02-2003 11:35:58
Dennis: Found the axle casting #, thanks to you. It is A3271R. The aa4060 special equipment according to the Two Cylinder Club is the cast disc rear wheels with 11-42, 6-ply and 5.50x16, 4-ply on front standard equipment for the "AW". Thanks for all your help. It has been a God-Send. SAM
