FACT of FICTION?
MIKE HANLEY
10-01-2003 17:19:28
When on an investagation, the cop has to belive what is told to him unless it doesn't pass the common sence test, or someone come up with a differant story. Then it needs further investagation. So heres the story I'm hearing now. John Deere has a patent on how the tops of the cylinders are formed on diesel pistons. So no after market piston can match the John Deere's in dezine. Deere has the pistons formed to get the proper spray pattern on the piston as engineered to the rest of the fuel system. Oversize after market pistons can pick up a couple of extra horses,,,IF,,, everything else is set so the spray pattern hits the spot that was dezined into that aftermarket piston. A wrong spray pattern and you can lose 10 horses. And every after market piston has a differant spray pattern. Been on the phone today and heard this story twice today. Advice I recieved today says if you don't have the know how on how to set everything else to match everything else up for that aftermaket piston, one is better off sheving back to factory and use John Deere pistons. Looking for comments here.
Steve - IN
10-02-2003 02:56:57
 Re: FACT of FICTION? in reply to MIKE HANLEY, 10-01-2003 17:19:28
Mike,
Patent Schmatent. Bull pucky. The life of a patent is only 17 years. Let's say the 720 or 730 piston was patented in '56 or '57. Add 17 years. It expired back in 1974 at best.
My guess would be there's some machine work that an aftermarket shop finds too costly to do, and still sell a piston and make a profit. Nothing wrong with that. We've all got to make a living.
If you want to run down whether the patent story is fact or fiction -- you should be able to find all JD patents and trademarks at
Link
Have fun with the search, but for practical things -- I'd go with aftermarket piece and ignore the stories about 10 horses living in the shape of the piston tops. May be true on a 500 hp engine, but with a 50 or 60 hp engine -- an extra 10? Naaah. Santa Claus only comes once a year.
MikeM
10-02-2003 06:01:57
 Re: Re: FACT of FICTION? in reply to Steve - IN, 10-02-2003 02:56:57
John Deere seems to be able to control parts better than most companies. I tried to get some Timken bearings for the steering worm on my 1936 B I think this is the only thing they fit. JD still sold them at ? dollars. My cousin works for Timken and could not get them because JD had them
tied up. But he could get some of the others. So tite wad me broke down and bought them from Deere. I'm glad JD still handles parts for old stuff as most other companies don't.
MIKE HANLEY
10-02-2003 07:29:28
 Re: Re: Re: FACT of FICTION? in reply to MikeM, 10-02-2003 06:01:57
Like that shock for the float ride seats. Made by GABRIEL. But it's a contract item only made for and sold to JOHN DEERE. No one else can buy them from GABRIEL.
Who owns the tooling?????
10-02-2003 07:50:07
 Re: Re: Re: Re: FACT of FICTION? in reply to MIKE HANLEY, 10-02-2003 07:29:28
I come from the aerospace world and there it is common practice for the customer to buy the hard tools and gauges. The supplier then agrees not to produce parts for anyone else on the customers tools/property.
General Electric and Pratt Whitney like to sell spare parts, too. It doesn't just happen with farm equipment.
F-I-T
Earl S.
10-01-2003 22:15:32
Call this number he can give you the answer to your pistons. 815- 778-1900 or 815-499-6580 central time 8-5
F-I-T
10-01-2003 20:22:34
Mike:
Have you spoken with Albert at Renaissance Tractor? I bought my 70D .045" over aftermarket pistons from him, and he also did my pumps and injectors. I set the timing, set the rack adjustment, and it has no nasty smoke. It made 52 hp on the dyno, which was just fine with me. All I wanted was a stock engine.
Albert rebuilds these engines every day for a living, and if it was that hard to get it right, I think I'd have heard that from him during our many e-mails and conversations. His number is 800-784-0026. E-mail is [email protected]
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
MIKE HANLEY
10-01-2003 20:40:31
 Re: Re: FACT of FICTION? in reply to F-I-T, 10-01-2003 20:22:34
I got the same answer from "2-cylinder diesel shop" and from "two cylinder plus". The reason I'am asking is that the co that made the oversize pistons no longer makes them and even though the pistons are good the machine shop that is doing the reboreing tells me they are thay are haveing a problem getting rings to match those pistons. So in calling around for that, both the above places tell me the same thing. That gets me to thinking that the way to go is to go back stock. Just like you, I'm not looking to SUPPE UP the engine, only get back to the factory horse that is to be there.
Bob
10-01-2003 21:23:59
 Re: Re: Re: FACT of FICTION? in reply to MIKE HANLEY, 10-01-2003 20:40:31
I don't know if it is appropriate to post this to this site, but since your email is not posted, here goes!
For piston rings for darn near anything, try:
OTTO Gas Engine Works
2167 Blue Ball Road
Elkton, MD 21921-3330
(410)398-7340
EMAIL dave.reeddol.net
http://www.enginads.com/otto/
F-I-T
10-01-2003 20:54:14
third party image
Mike:
I'd still call Albert. I'd be curious to see what he has to say. Perhaps he'll stop by on this thread and comment.
When my pistons arrived, included was a box of Hastings rings. I have the number in the shop.
Curious....how did the injector pattern look on your pistons? Did it look even and with wide dispersion?
I don't know the other shops you spoke to. All I found out was that 70D pistons were no longer available, and that 730 pistons were now the only option. All that Albert told me was that if I installed 730 pistons, and later if I chose to find some pumps and injectors from a 730 (13mm), I could expect 730 horsepower. Maybe I will someday.
Here's a picture of my new pistons. I still have the old original JD standards.
MIKE HANLEY
10-01-2003 21:04:54
 Re: Re: Re: Re: FACT of FICTION? in reply to F-I-T, 10-01-2003 20:54:14
That looks like them. In side are the logo GEP in a ovel. There is a post below that thinks they were made by GENERAL ENGINE PRODUCTS that now only makes engines for the hummvee. I have to deciece what to do as the block goes the get rebrored and will cost no more to bore to the .090 over that the pistons are or to go back to0 factory. the cost extra would be the new pistons.
MIKE HANLEY
10-01-2003 21:11:46
 Re: Re: Re: Re: Re: FACT of FICTION? in reply to MIKE HANLEY, 10-01-2003 21:04:54
OPPS. I mean rebore AND sleave 6he block. It is midnight, and I'm half leasing to LENO.
