How many is a lot?
fred
01-20-2004 18:40:48
Im interested in a 4020 & was wondering how many hours a typical engine / tractor was good for? Thanks
jdemaris
01-21-2004 06:39:28
 Re: How many is a lot? in reply to fred, 01-20-2004 18:40:48
Average engine life for a 4020 is 10,000 hours. Most that I've rebuilt still ran fine at 10K but were using oil or starting hard, and subsequently torn down. One note - I've noticed that many tractors, once they get high hours on them, don't get proper care, and suffer from it. I've rebuilt my neighbor's 4020 twice since it was new. Both times, he blew a piston at around 10,000 hours . . . and both times it was because he overheated it due to a coolant leak he hadn't fixed. Once money is invested in a rebuild, the tractor sees better care for awhile. When I worked for a Deere dealer, I saw this happen a lot. Same neighbor just seized the engine in his 100 horse Deutz-Allis air-cooled engine - all because of a bad belt on the air blower. That's makes an expensive fan belt. So, point to my story is . . . I suspect a 4020 could get well over 10,000 hours before a rebuild with proper care.
will
01-21-2004 05:34:19
My late model now has a hair over 18000, and I would not be scared to go to the field tomorrow. It made it to 12,000 before its overhaul. The only engine problem was a bent pushrod at about 8000 or so hours.
Mary
01-21-2004 04:29:08
I saw where Peter and Paul had already replied.
Joe P.
01-21-2004 05:10:34
 Re: Re: How many is a lot? in reply to Mary, 01-21-2004 04:29:08
Hey..... ...You're pretty funny!!
Pete/ME
01-21-2004 03:07:25
I've heard from different guys over the years that diesels are good for about 7,000 hours before an overhaul. The tractor will last for as long as parts are available and you fix what breaks or wears out.
Paul
01-20-2004 18:58:20
almost unlimited if proper care and repair work has been done. many of these tractors have 20,000 or more hours on them almost all that have made a living have 10,000 hours.yes they have been overhauled and updated but they were made to be used and worked on. rather than hours look at general condition has it been kept up, cleaned and refitted with oem type parts.if it has itprobably had oils and antifreeze checked and changed regularly. if it looks like a cobbled up p.o.s. it probably IS. Paul
