Adjusting loose steering play
JD-G
10-01-2003 13:43:35
I have alot of slack in my steering on the G. I've removed the bolt that is seated between the notches on the bushing which screws into the pedestal housing. Then I started turning the bushing under the sector gear to move it toward the worm gear as close as possible. It tighted up some of the steering but still have a lot of play before wheels actually turn. Is this the correct way to adjust this and are these gears typically this worn out? If this is the case, where can I get another sector gear or bushing that would be in better shape than mine. Thanks in advance for help.
Frank Kovarick
10-02-2003 23:09:45
 Re: Adjusting loose steering play in reply to JD-G, 10-01-2003 13:43:35
You may want to go further in the source of the steering play. I have an "A" and it got real loose and wouldn't resort to the offset bushing to tighten. I noticed that I could pull the steering wheel in and out by pushing and pulling on the column. With the front wheels off the ground, this would turn the wheels left and right. When I took the bearing end cap off the end of the steering column, the end bearing was shot and missing most of the rollers. I went to a bearing place and they ordered just the rollers in the cage from "Allied" in TX for about $50 for 3. 2 costs $39 plus shipping and 3 were $42 plus shipping. A good John Deere place could probably order them too. The inner cones on the bearings must be welded to the column. And the outers are replaceable but with a lot of trouble. You do know how to remove the steering column? Take the steering wheel off and then the bearing end plate off at the pedestal and pull the column, all 6 feet of it out the front.
JD-G
10-03-2003 08:52:01
 Re: Re: Adjusting loose steering play in reply to Frank Kovarick, 10-02-2003 23:09:45
Thanks for the feedback Frank. I've replaced these bearings from John Deere, but the worm gear on the shaft and sector gear still don't come together all the way whenever I turn the bushing under the sector gear to move it over.
Clooney
10-03-2003 19:10:00
 Re: Re: Re: Adjusting loose steering play in reply to JD-G, 10-03-2003 08:52:01
JD-G, that serrated bushing has an off-center hole [that's why it's called an eccentric]... What happens on a lot of those old tractors is that center hole wears [in the direction away from the sector gear]. That places the hole [well it is actually a slot by now] in about the center of the bushing & no amount or turning will close up that worm to sector gap. ~That eccentric bushing is real hard to come by so what I usually do is remove that bushing & chuck it up in a 4 jaw chuck in my lathe then bore the bushing hole out off center again then install a brass bushing...That will allow it to work as an adjuster again..
F-I-T
10-01-2003 14:50:44
JD-G:
There a lot of threads dealing with that problem in the archives. It's pretty common on the old row crops.
You have basically three adjustments you can make. Steering shaft fore and aft, pedestal shaft vertical end play, and eccentric tilt for sector to worm mesh.
The vertical adjustment involves jacking up the front of the tractor, putting a dial indicator on top of the shaft, and using another jack or a lever, lift the shaft up and down to see if it's excessive. Most folks skip this adjustment if they don't have too much front wheel flutter.
So, check the fore and aft shaft play next. Move the sector eccentric away from the worm so you can feel and/or measure the endplay. Add or (probably) remove shims to make the clearance so that the shaft turns without a ton of effort but it doesn't move in and out as you turn it.
Now you can set the sector to worm mesh using the eccentric adjustment. Here I like to have the front end jacked up so I can really feel for any interferrence. Make the adjustment at either near extreme left or right. This areas have not seen much wear, and if you adjust in the sloppy center, she will be sure to bind on the end of travel turns.
By now you will have removed all the play you can without replacing parts. If it's still sloppy, you might have a bad bearing(s), or sector/worm worn too bad to adjust.
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
