'41 A CARB TROUBLE
Jon Z.
10-01-2003 12:04:37
The bowl on my '41 A carb was loose and when I wennt to tighten it, the nut stripped off and a spring fell out. Is there anything above the spring? The spring is all I found. The threads on the carb are stripped. Any advise on how to fix it so I can get her running?
Thanks, Jon Z.
Paul from MI
10-01-2003 19:15:58
 Re: '41 A CARB TROUBLE in reply to Jon Z., 10-01-2003 12:04:37
You might also try Doug Burrey at 800-287-7390. He did a great job fixing the same problem on my B. This is a common problem on the older carbs. It's also a dangerous one. If that thread lets go because of a poor repair, you are going to have a lot of gas sprayed by the fan onto a hot manifold. Pretty darn good way to build a fire, which you don't want. Have it fixed right, this is not the time to cut corners. Good Luck,
Paul
Greg
10-01-2003 12:42:23
Jon,
If the carb on your A is a DLTX model, then there is a nozzle above the spring. Don't worry, it didn't accidentally fall out. They usually are quite difficult to remove even when you want them to come out. As for the threads, are you sure the cast iron threads on the carb are stripped? If not, you may get off easy by just buying another brass nut from the JD dealer. If the cast iron threads are stripped, then you may want to send the carb to Robert's Carburetor Repair in Iowa. He can machine a new threaded portion and braze it on for you. His phone number is 712-262-5311. He did a nice job on mine.
