JD 4010 LP tractor question...
Eric
10-01-2003 09:15:19
I just inherited a late 60's to early 70's 4010 LP tractor. I own several other tractors but have never used/operated a propane tractor. I have a 2 main questions: 1. The two round knobs above the instrument cluster that go all the way to the LP tank in front, are they for mixing the LP to air mixture? If so how are they used? 2. What are the starting instructions for the tractor?
TIA
G-MAN
10-01-2003 10:48:29
 Re: JD 4010 LP tractor question... in reply to Eric, 10-01-2003 09:15:19
For the safety of you and your tractor, the BEST thing you could possibly do is obtain a copy of the operator's manual for your tractor (make sure to get the LP version), and read it thoroughly before operating or servicing the tractor. Your local JD dealer can order one for you, or they may happen to have an old one laying around. They are relatively inexpensive and are must-have - particularly for a tractor you have no experience with or knowledge of. If it were me, I'd also have the LP system checked out for leaks and proper operation, by somebody qualified to do so, particularly if you plan on parking the tractor inside. LP-gas is safe if used correctly, but is nothing to screw around with. And one other thing, if it's a 4010, it would be a pre-'64 model. The 4020 was introduced for the '64 model year.
mike-nm
10-01-2003 10:18:33
Eric, those round knobs are the vapor and the other one is liquid- to start your tractor, first turn on the vapor one and hit the starter, after she starts and warms up turn on the liquid knob and turn off the vapor knob. Thats all you have to do. Always turn off both knobs when the tractor is not running. -mike-nm
Eric
10-01-2003 11:54:14
 Re: Re: JD 4010 LP tractor question... in reply to mike-nm, 10-01-2003 10:18:33
Thanks for the reply. Do you happen to remember which is which? Is the left the vapor or liquid? Best I can tell, they are not labeled.
Any hints for the process of filling the fuel tanks? She might be out of LP
TIA
mike-nm
10-01-2003 12:40:06
 Re: Re: Re: JD 4010 LP tractor question... in reply to Eric, 10-01-2003 11:54:14
Eric- The dashboard on your tractor should have a V over the knob for vapor and the liquid should have a L over the knob, on my tractor the liquid knob is on the left as you set on the seat and the vapor is on the right. to fill it you must have a large supply tank and a "wet" line. I have a 500 gal tank that is set up to fill my tractor. if you are not equipped to fill propane bottles I would suggest you call up your lp supplier and have them come out to your place and fill your tractor and then you can watch the guy and ask questions,also if you are on propane already (winter heating-etc.) have the man look at your tank to see if it's set up to get liquid propane. hope this helps -mike-nm
Wayne in Tn.
10-01-2003 12:29:50
Eric, I don't know about the 4010, but I have a 420 and the right knob is the vapor and the left knob is liquid. As to filling the tank, that is going to depend on your local Lp company, they have got real strict about filling tanks. You may get a hose made up by your Lp dealer to use with an ordinary home tank. In my area the Lp dealer said he would fill mine from his truck, when in the area. Another dealer said they would not fill anything on wheels, so..... I wound up hauling mine to another dealer and he filled it at his place. It is all going to depend on the dealers in your area.
Eric
10-01-2003 12:58:42
 Re: Re: Re: Re: JD 4010 LP tractor question... in reply to Wayne in Tn., 10-01-2003 12:29:50
OK guys, thanks for the follow-ups. One last question on the Vapor and Liquid valves. Is full counter clockwise open or closed for the valves?
TIA
G-MAN
10-01-2003 13:20:07
 Re: Re: Re: Re: Re: JD 4010 LP tractor question... in reply to Eric, 10-01-2003 12:58:42
Fully clockwise is closed, fully counter-clockwise is open. Like I said, invest in the operator's manual.
Eric
10-01-2003 13:23:38
 Re: Re: Re: Re: Re: Re: JD 4010 LP tractor questio in reply to G-MAN, 10-01-2003 13:20:07
Thanks, I have already odered the manual but it take 2 weeks to get it in and work needs to be done before then. Thanks for your advice...
