Thanks Dave, where you been lately?? If theres any new generation or 24 volt 2 cylinder questions, Pleaseeeee e help us all. Jack, Using the great info Dave posted above, if that tractor still has all the components (wasnt cannibalized or converted??) for a 6 volt coil and ballast system, heres more info. 1) YOU MUST install a Ballast (usually a wire wound ceramic of 1.5 to 1.85 ohms at 25 watts or so) usign a 6 volt coil. If nones there, buy one at Tractor Supply or Rural King or Central Tractor or John Deere or NAPA ECH 1CR13, and it is wired in series with the circuit from the ignition switch output (IGN etc terminal, hot when Ign switch ON) down to the coils high (not to distributor) side. It drops approx 6v leaving 6 for the coil. 2) Im prettry sure that tractor uses what I call a Ford type solenoid (Right Dave???). It has the 2 big terminals for the battery and starter cables and 2 lil ones labeled (S)olenoid and (I)gnition. The S one is hot when the start switch is energized to close the solenoid and crank the engine, while the I one is hot ONLY when the solenoid is engaged. (I think?? thats right) 3) Run a 14 gauge insulated wire from the solenoids I terminal to either the coils high (not to distributor) side or the low (not to switch) side of the ballast, thats the SAME elecrical point. 4) YES, its possible to improve starting that way (with ballast by pass installed and working) CUZ when cranking, the coil then gets battery voltage INSTEAD OF the reduced voltage it sees with the ballast is in the circuit. Once the solenoid is disengaged, the I terminal is not hot so the coil only sees the voltage remaining after the ballast drops approx 6 or so volts across it. 5) The reason for the ballast on a 12 v system with a 6 volt coil is to limit the current flowing thru the ignition points so they dont burn up prematurely and so the coil sees the right voltage and current so it doesnt overheat and degrade. I had an article published on this subject in Green Magazine some time back, e mail me if you want a copy. 6) If the tractor is pos ground, wire the coils - to ballast and + to distributor, or if its neg ground, + to ballast and - to distributor. 7) If shes hard to start however, the ballast by pass is no sure answer or cure, its more helpful in cold weather. Be sure the points are clean, gapped proper, no gray oxide coat or burned or pitted or carboned over and try a fresh set of spark plugs and see what happens. If the tractor and ignition is in good shape, she ought to start right up but if not, the by pass may not help it all that much. Good Luck n God Bless John T Nordhoff in Indiana Good Luck, Im glad Dave enlightend us all and hope the above solenoid is the kind I think it is with the S and I terminals. John T [email protected]
