'45 JD GM hand crank / modern grill - rarity?
Hank
10-01-2003 06:44:32
I guess I'm still not clear in my question, sorry. What I want to know is the rarity of a G from 1944-1952 with the modern grill AND a hand crank (by modern grill I do mean the "horizontal ribs and eight screened openings on it". The old type is the wide open steering post, I've seen hand cranks with the open post but not the modern grill. I've not seen any with my combination, any one else's thoughts?
easydoesit
10-01-2003 09:11:01
 Re: '45 JD GM hand crank / modern grill - rarity? in reply to Hank, 10-01-2003 06:44:32
Hank, I have two hand crank GM's. I don't know if they were factory electric starters. A left hand main bearing housing w/o starter bracket and no wiring says probably original hand start. I love them but I don't consider them very rare. Easy
Hank
10-01-2003 09:18:05
 Re: Re: '45 JD GM hand crank / modern grill - rari in reply to easydoesit, 10-01-2003 09:11:01
Thanks again for the comments, interesting. Easy, what part of the country are you in? I'm in central Iowa.
Hank
easydoesit
10-01-2003 14:38:04
 Re: Re: Re: '45 JD GM hand crank / modern grill - in reply to Hank, 10-01-2003 09:18:05
I'm south of Nashville down in Tennessee. I picked up some G parts in Iowa about a month ago.
Jack
10-02-2003 04:52:50
 Re: Re: Re: Re: '45 JD GM hand crank / modern gril in reply to easydoesit, 10-01-2003 14:38:04
Murfreesboro area?I went to a good pull and show back in the season up your way in a big pavillion.Were you there also?Jack(Dresden).
Stan - Florida
10-01-2003 08:54:36
And I guess I didn't read enough into your question. I dug into my old Green Magazine file and found an article on the 'GM'. Of the six pictures in the article, three show a hand crank flywheel, but in reading the text, I find these selected comments: "efforts were made to equip as many 'GM' tractors as possible with electric starting and lighting, as hand cranking a reluctant 'GM' could wear you out in short order". "it would be rare to find a hand-crank 'GM' equipped with the lighting option".
Serial number breaks (from the same article) are 1942 - 13000-13417; 1943 - 13418-13747; 1944 - none built; 1945 - 13748-15779; 1946 - 15780-18522; 1947 - 18553-22112. Total production was 8764 tractors, with 348 serial numbers scrapped replaced or otherwise not used.
Back to your basic question - it looks as though the hand crank option was fairly rare, which is as close as I can get to an estimate.
Stan
F-I-T
10-01-2003 07:07:50
Hank:
Your early styled "G" is know as a "GM" ("G" Modernized). The designation had to change because of wartime pricing rules. You can search the archives and read about that.
According to the parts book, the hand crank flywheel was listed for tractors up to #25999 (the end of the GM series). When the "G" with the square battery box and seat came out, electric starting and lights became standard equipment. Your tractor could have been an original hand start, or it had a hand-start flywheel installed after the fact as a repair, especially if there is evidence of any electrical equipment or remnants of wires, but it is certainly possible that this tractor was not equipped with electric starting. Unless I am interpretting the parts book incorrectly, it was legitimate to be able to buy a "GM" with out electric starting.
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
DPOST
10-02-2003 06:53:54
 Re: Re: '45 JD GM hand crank / modern grill - rari in reply to F-I-T, 10-01-2003 07:07:50
Hi Gang;
My interpretitation of the G parts book was that the "standard" version of the GM was no lights and no starter. One option was to add 6 volt batttery, lights and a generator. A second option was to add 12 volt battery ( two 6 volt batteies ), lights, starter and a generator. Both options put the battery in frot of the valve cover. The GM with option 2 seems to be the most common.
Our GM has option 2, but it keeps trying to become the standard version. The lights haven't worked in years and the starter is on the bench in pieces waiting for someone to fix it.
Our 45 vintage GM is also a bit weird as it has a Delco Distributor and a correctly placed igniton switch yet the parts book says this wasn't available till ser 26000. Was this a dealer up grade or did it come that way? Am I reading to much into what I see in the parts book? If the tractor had a mag replaced with a distributor, it would have to had to be done when the tractor was farely new as we have owned it for 45 years.
Take Care
D.D.Post
F-I-T
10-02-2003 14:20:54
 Re: Re: Re: '45 JD GM hand crank / modern grill - in reply to DPOST, 10-02-2003 06:53:54
DD:
I might be able to offer a plausible theory.
When my dad bought his '48 'A' used in 1950, it had a WICO X magneto on it. It failed shortly after delivery, and the dealer said he would replace it or install a distributor for him. Dad opted for the distributor, and they installed a WICO XB distributor. Farmers back then were believieng that they would get better low speed (idle and lugging) performance with a distributor. My uncle had a 1952 'B' and the mag failed on it so he bought a kit at the dealer to retrofit it with a distributor, and it was a Delco.
I'm betting that the mag failed at one time and someone found a good deal on a Delco distributor. I bought a '49 'A' about 20 years ago, and it had a Delco distributor. They sure were easier to keep going. The WICO's had everything really crammed in there, including the very expensive coil!
Frank
