Fusable link
SteveWswMI
10-01-2003 05:43:27
Was planning on running a wire jumper on my M where the fusable link was. Any real danger on a tractor that gets used for cultivating only?
Dave K (FL)
10-01-2003 13:39:06
 Re: Fusable link in reply to SteveWswMI, 10-01-2003 05:43:27
Have a 48 Model A that was not protected. Generator hot wire got pinched under something and smoke and flames erupted! Pulled a battery lead in quick time! Bought an inexpensive automotive type in line fuse at Wallmart, hooked it up so everything but the battery lead to the starter goes through it. Buried it in the harness so even the correct police can not see it and, after some rewiring, everything works fine and is protected! Oh yeah, glad I had a fire extinguisher on the tractor as the dash went up in smoke and some flame and that was too close to the fuel for me!
Dave
Clooney
10-01-2003 11:21:09
Steve, I'm not familiar with a fusible link ever being used on a Deere "M". The "M" did use an inline tubular fuse at the IP area for light & ignition protection though.
~You could eliminate that fuse if you want to as the larger 2-cylinder Deere's didn't use a fuse in that circuit [not sure why the Dubuque�s did].
~You can just use any cheap inline plastic fuse holder & a 20 amp tube fuse as those are real cheap at your local auto parts store or Radio Shack...
[email protected]
F-I-T
10-01-2003 08:19:05
Steve:
You might consider using a circuit breaker in lieu of a fusible link. The automotive circuit breakers have a heater in them. When they see over-current, they open, but they auto reset when the load is removed. You can buy them at auto parts stores in a variety of sizes. Easy to install and good safety feature. Deere uses them in a lot of their newer designs.
Frank
John T
10-01-2003 06:16:24
Good Morning Steve, the danger of not over current protectign the circuit you asked about, like any other similar circuit, is a short could potentially cause high current and resultign heat and/or arcing sparks which could ignite gas or gas vapors. It could also potentially protect other equipment downstream and served from that wire source from shorts and high current. Instead of by pass shortign around any factory installed or factory designed fuse or fusible link (serves same purpose) I suggest you install at the minimum one of those inexpensive in line fuses. Its true there are plenty other places on that or other tractors where wires or circuits are not over current protected, but as an elecrical engineer I just feel its better to be safe then sorry, especially where an inexpensive original type fuse for that tractor or a fuse link or an after market in line fuse could easily be installed.
Many tractors have no fuses or links and the light gauge 14 wires would melt under a dead short, but on new wirign I like circuits to still be protected even where its not original or the corect police may not like it. Especially in cases where the tractor originally had a fuse, I would definitely use one, be it original replacement or after market.
Good Luck n God Bless
John T Nordhoff
RickB.
10-01-2003 05:48:53
Doesn't matter what you use it for. It's all about whether or not you developa short circuit somewhere. There is really no reason for circuit breakers in your house, unless something goes wrong. But I am going to leave mine in for now. New Holland uses a 30A fusible link on their 10 and 20 series compacts that is cheap, and should be adaptable to just about any tractor. May well be in stock at your NH dealer. Seems Kubota commonly uses one as well.
