HELP! John Deere 740 hitch problem...
Tim K.
09-30-2003 21:21:16
I was working with a blade on my 750 when the three point hitch stopped lifting. I traced the problem to the rocker shaft mechanism. It seems that the rocker shaft works a metal piece that, when working correctly, holds pressure on the hydraulic valve that works the hitch. When I move the metal lever backwards with my finger it allows the hitch to lift however, when I let it go the hitch drops. Is there suppose to be a spring holding tension on the metal piece or did I break pin or something that works the metal piece?
Tim K.
09-30-2003 21:22:58
 Re: HELP! John Deere 740 hitch problem... in reply to Tim K., 09-30-2003 21:21:16
Sorry that was suppose to be Johne Deere 750 hitch problem..
