JD 520, PTO clutch not working
Gene Snipes
09-30-2003 19:45:34
The PTO clutch won't work. PTO works if engaged but clutch can't be pushed in. It is either on or off. Where would I start. I have some shop manuals but this is 1st attempt at fixing any tractor and I'm 58 years old. Want to restore a couple of these 520's but afraid to start.
gene snipes
10-01-2003 13:49:49
 Re: JD 520, PTO clutch not working in reply to Gene Snipes, 09-30-2003 19:45:34
I've used a 6-foot bushhog on it by turning on the PTO with the lever, since the clutch is engaged, when I start the tractor, the mower works and I can mow - kind of dangerous as I can't stop the mower without kicking the lever pretty hard or just turning off the tractor. But I'm on level ground and no rocks or stumps so I do it to keep the area trimmed. Just want to fix it so the foot PTO clutch works.
I will check oil level and attempt to adjust the "adjustments" mentioned in other posts.
Thanks.
ChuckW
10-01-2003 13:33:17
It sounds as though all your attempts at checking is without any implements being attached. In my opinion that someone may have been using tractor, then let it set with the clutch engaged and possibly the clutch pack is stuck. I would use a bushog, start it up and use the bushog, disengage the clutch then and see if it all release. It will be a jerky start up(only thing I don't like), however your clutch pack may simply be stuck. You need to mow some heavy grass then release the clutch. This should make it break loose.
10-01-2003 08:49:30
Something in your explanation doesn't quite make sense. Which clutch can't be pushed in? Where are you "engaging" the PTO when you say it "works if engaged". Seems to me the clutch would have to be working if the PTO "works when engaged".
Better get yourself a manual which is still available from Deere at 800-522-7448 and have a credit card ready.
RickB
10-01-2003 08:59:17
 Re: Re: JD 520, PTO clutch not working in reply to ????, 10-01-2003 08:49:30
TO Noname, your answer indicates you are not familiar with a 520, and didn't pay attention to Gene's post. When the disconnect is disengaged, the PTO is off. When the disconnnect is engaged, the PTO drives. He says he has the shop manual. TO Gene: You have a PTO clutch linkage or PTO clutch problem. The discs may be warped and locked up, for instance. Read up thoroughly, and dive in if you want to. Be aware the seal between the PTO unit and transmission may be bad. This allows several gallons of fluid to drain out through the PTO instead of the few quarts you may expect. Don't ask how I know THAT!
from Noname
10-01-2003 17:30:23
 Re: Re: Re: JD 520, PTO clutch not working in reply to RickB, 10-01-2003 08:59:17
I am familiar with the JD live PTOs and the 520's is not much different from a 50 which I own and have done a complete repair on its live PTO.
gene snipes
10-01-2003 11:08:29
Rick, are you saying that when I take the adjustments cover plate off, I may have 4-10 gallons of oil coming out?
Gene
RickB.
10-01-2003 11:38:57
 Re: Re: Re: Re: JD 520, PTO clutch not working in reply to gene snipes, 10-01-2003 11:08:29
That is a possibility. I drained the "PTO housing" on my 730 late one afternoon by pulling the PTO housing drainplug with a two gallon pan under it. Shut off the lights and went home. Came in the next morning with the entire contents of the transmission and PTO housing on the floor. Except for two gallons, of course. You may not have this problem.
Gene Snipes
10-01-2003 11:05:35
OK, here is a redefinition of the problem.
There is an on/off lever for the PTO. It works just fine. I can turn the PTO on and I can turn it off.
The PTO clutch does not allow me to stop the PTO when the lever is in the "On" position. So I guess you'd say the clutch is stuck in the "clutch out" position. Otherwise, the PTO clutch does not operate as it should. I've been reading the several posts on this forum about PTO problems and will attempt to adjust the "adjustments". But I am new to this, so be patient.
Thanks for all of the comments, so far.
Gene
RLA
10-01-2003 13:29:04
 Re: Re: Re: Re: JD 520, PTO clutch not working in reply to Gene Snipes, 10-01-2003 11:05:35
Gene?
Have you checked to see if its over full? There's a check plug, unscrew it & see how much oil drains from the check plug. Does it operate the same way hot as it does cold? With the foot pedel in the off position & the hand lever in engauged position can you turn the pto shaft with leverage? The clutchs's just may be stuck, to be sure, there's only one way to find out!
RLA
