37 B RING POSITIONING
hal
09-30-2003 18:34:45
what is the correct way that the lower (oil) ring goes on 37 B piston i got new rings from deere and all had a dot on them just like deere said except the oil ring and it has a taper to it i think it should be with taper pointing up but want to be sure before i put them in thanks hal
Greg
10-01-2003 12:51:48
 Re: 37 B RING POSITIONING in reply to hal, 09-30-2003 18:34:45
The bevel on the upper edge of each ring face causes the ring to ride over the oil film as the piston moves toward top dead center (TDC), but as the piston moves downward for intake and power, the sharp lower edge of each ring scrapes or wipes the oil from the cylinder wall.
Will P
09-30-2003 20:42:05
I asked the same question about 2 years ago too. The tapered part goes toward the top of the piston. The square edge goes toward the bottom of the piston. Hope that is clear.
Will P
