John Deere 3020
basil greenleaf
09-30-2003 18:16:08
JD 3020 deisel.Why won't the clutch release when pedal is depressed? Can slip it into gear with considerable gear clash. Clutch has been loosing pedal free play over a short period of time. New clutch plate was installed approximately 50 hours ago. Any help out there?
Gary in TX
10-01-2003 07:00:43
 Re: John Deere 3020 in reply to basil greenleaf, 09-30-2003 18:16:08
First thing I would check would be to make sure the clutch adjusting bolt on the pedal where it goes into the bell housing is tight and has the cotter pin locking it in adjustment. If that sucker is loose I would imagine that you would get the results your talking about.
Mr. Green
09-30-2003 18:51:31
First i would take the bottom plate off, and look up inside. The clutch release bearing may be bad. The clutch release levers may have come out of adjustment.
