RB70D, you didn't give quite enough information to give a definitive answer� But here are some possible causes of a problem like yours. ~At the top of the list would be the wrong polarity regulator for your battery ground polarity. Is your tractor still wired as a positive ground? If not, swap the battery cables & re-polarize the generator. If your tractor is still the factory positive ground verify the regulator is definitely for a positive [or both positive & negative ground] system. ~Next on the list would be that you have the wrong wires hooked to the regulator's [BAT] & [GEN] terminals. Don't go by the position in the book or furnished wire diagram but use the actual markings on the regulator's terminals. The regulator�s [BAT] terminal should be wired to the ammeters non battery side & have power on it at ALL TIMES�.The [GEN] terminal on the regulator should be wired to the generators [A] post [larger of the two]. The regulator�s [Fld] terminal should be hooked to the generator�s [F] post. ~Next on the list would be you have the fuel gage power wire hooked up to the wrong regulator terminal [it should go to the {GEN} terminal on the regulator. OR, the fuel gage power wire is improperly wired at the dash switch & effecting the regulator�s operation. [try disconnecting the fuel gage power wire from the regulator & see if the generator then charges like it is supposed to]�If removing the fuel gage wire from the regulator makes the system function correctly post back or E-Mail me for a trouble shooting sequence on that fuel gage system on that diesel. ~If nothing found so far you could have a regulator or generator ground problem as Frank mentioned [especially if you painted the regulator or generator while off the tractor]. ~If the grounds check out ok you might just have a generator problem like a sticking brush or dirty commutator & re-polarizing the generator gets it to work until it sits for a while again. ~If nothing helpful found in the above you will have to run a charging system test on the charging system�. ~~~~~~~~~To test the charging system~~~~~~~~~~ --First, remove the fuel gage power wire from the regulator [that should be the second wire hooked to the regulators {GEN} terminal]. --Then start the tractor & run at fast idle, now ground the generator�s [F] post to the generator�s frame [case]�[If it charges then, suspect a bad regulator ground, or a bad regulator, or an open in the wire from the generator�s [F] post to the regulators [Fld] terminal. --If it still doesn�t charge leave the [F] post grounded & jump the generators [A] post to the regulators [BAT] terminal.. If it charges then you have a bad regulator or improper polarity regulator for your system, or an open in the wire from the generator's [A] post to the regulator's [GEN] terminal...If it still doesn�t charge, re-verify you have battery power at the regulators [BAT] terminal [that terminal MUST have power at all times or it will never charge]. If you do indeed have battery power at the regulator�s [BAT] terminal then you have a generator problem like stuck brushes or dirty commutator. --Seeing as it will show a charge after you re-polarize the generator, then doing a generator test won�t tell you much so you will probably just have to pull the generator apart & clean the commutator & free up the bushes� ~It helps to print this page out & take it out to the tractor with you while working... ~One last thing�When you polarize the system you are really polarizing [magnetizing] the GENERATOR field shoes,. There is nothing in a regulator that can [or needs to be] polarized. [email protected]
