B 3 point hitch
Daniel Chestnut
01-20-2004 17:19:26
I finally got around to putting the 3 point hitch on my B yesterday. I think it a model 800, but I'm not sure. I found it laying out in my grandfathers tractor parts row next to some JD cultivators. I now have everything mounted on my B, except for the top link. There was two long rods with square bar inbetween laying there with the rest of it, but I thought it went with the cultivators. Does anyone have any pictures of a 3 point hitch like this that shows the top link parts?
Also, what size is the top radiator hose?
Thanks in advance.
JDVan
01-20-2004 21:56:46
 Re: B 3 point hitch in reply to Daniel Chestnut, 01-20-2004 17:19:26
Daniel:
What you found in the fence row is worth almost as much as the "B". There are three different versions of the 800 series hitch. The top arms with the bar between attach to the rear axles with brackets. On an 800 series hitch these arms are equivalent to a conventional three point Top Link. However, during the 800 series hitches era there were adapters (Mast brackets) sold to make conventional three point implements compatible with the 800 series hitches. A previous message has however, outlined a way to make the Evener Bar compatible with a three point implement. There are other ways as well.
I have several 800 series hitch pictures on a public site. These might help a bit and also help you identify which version you have:
See link below:
Daniel Chestnut
01-23-2004 16:34:19
 Re: Re: B 3 point hitch in reply to JDVan, 01-20-2004 21:56:46
I got the two mounting brackets that the top link pieces mount to on the axles tonight at a local tractor place. I wasn't able to find them with any of the other 3pt hitch stuff. Hopefully the weather will be nice tomorrow so I can put the rest of the hitch on.
JDVan In your reply to my first message, you said "What you found in the fence row is worth almost as much as the "B"". What is an 800 hitch worth? It is missing the sway chains.
Thanks for the replies.
Mike M
01-21-2004 13:06:08
Wow !!! those are the hotest hitches yet! I went to that site hit a wrong button and wow what a nudi show !! P.S. Do you know that there was once a U shaped piece of metal with a hole in it to slide down over the crank to keep it from turning ? Also if you use that hitch I would recommend flipping the top link adjusters over so that the little handles don't fall out.
JDVan
01-21-2004 13:19:48
 Re: Re: Re: B 3 point hitch in reply to Mike M, 01-21-2004 13:06:08
Mike:
I don't know what wrong button you hit but there are no "Nudi" pictures on my site. yes, there is a clamp that goes over the lift crank on the 800 version of the hitch. I've never seen one however. Most if not all are missing.
The adjustment handles on the upper links are arranged to lock in the cast forks so they don't fall out. I'm not sure I understand your concern about them falling out.
Mike M
01-21-2004 19:20:32
 Re: Re: Re: Re: B 3 point hitch in reply to JDVan, 01-21-2004 13:19:48
It was the home fotki site that sponsors that. You may want to check it out or not ? I probabably just got overcerned about seeing things flopping around after seeing those women. Maybe I should start making some of the locks from my pattern ?
JDVan
01-21-2004 19:28:06
 Re: Re: Re: Re: Re: B 3 point hitch in reply to Mike M, 01-21-2004 19:20:32
Well, a little education never hurt anyone. :-) I might be interested in a few of the locks if they were reasonably priced.
will
01-21-2004 08:07:41
What is a complete 801 lift hitch worth? Mine is missing the evener bar and one sway chain, Parts which are replaceable thankfully.
JDVan
01-21-2004 09:53:07
 Re: Re: Re: B 3 point hitch in reply to will, 01-21-2004 08:07:41
An 801 version of the hitch is the mose desireable from a collectors point of view. I would not describe a hitch as complete unless all the parts are there including the connection pins, clevises, chains, push rods, eyelets, etc, etc. The condition of the hitch pieces can also have a impact on the value. Are there any welds or cracks. Anything bent? Do the draft arms slide in and out? Is it correctly configured with all 801 hitch parts, etc. The range in value could be from $400 to $1,000 if truly complete and restored. Several completely restored and almost complete hitches have sold on eBay for over $1,000.
will
01-21-2004 10:43:19
 Re: Re: Re: Re: B 3 point hitch in reply to JDVan, 01-21-2004 09:53:07
If you will give me your email address I will send you some pics when I complete it, and you can perhaps give me an assessment and comments. I do have the pushrods, and eyelets. I am missing the bar betweent the upper arms, and the pin that goes throught the bar, and one sway chain and the two clevis and pins that go with that sway chain. I may be missing a pin or two I have yet to reassemble after blasting and paint. It has no bends other that the lower lift arms that have swelled ends near the tractor where water collected and froze I presume. That is pretty much the only flaws. What is a good parts source for these hitches? What parts are still available? Thanks so much for the help and comments.
Ron
01-20-2004 21:19:57
Yes, those other arms bolt to the inside pairs of axle-housing bolts, under the rock-shafts.. That square piece in-between them is what will connect to the top link of your implement... I use a forged "Eye-Bolt" thru it, with large washers, and a spacer, and tighten it tight to the equipment mast..put the top-link bolt thru the Eye of the bolt..
old
01-20-2004 18:51:54
If I remember right its 2-3/8 inch
