G is finally running
JD-G
09-30-2003 07:07:38
I posted a message a few days ago about having problems with the electronic ignition. After tinkering with it some more, I decided to put the magneto back on along with a cold manifold and another rebuilt carb. Timed everything like some of you suggested and she runs and sounds great. Now it's off to the pulls. Also, I checked each cylinder with a pressure guage and am reading a little over 100psi. Does that sound like enough compression, or should I have more? Thanks again for all of the help.
Jack
09-30-2003 13:07:48
 Re: G is finally running in reply to JD-G, 09-30-2003 07:07:38
With 100 psi you should be around 55 hp which makes a good farm stock puller.Good luck.
