3020 hard starter
perry
09-30-2003 05:33:19
I recently bought a 3020. Previous owner says it was a hard starter. I am changing plugs, and points. Do I also need to change the coil? What else would help? Any suggestions welcome.
thanks
jer
09-30-2003 20:46:32
 Re: 3020 hard starter in reply to perry, 09-30-2003 05:33:19
Check to see if the advance is stuck in the distributer. If it is spray lube on it and work it back and forth till it frees up. Also check for broken springs in the advance. I have seen this happen before.
twopop
09-30-2003 09:10:15
The ignition switch on the 20 should have a resistor built on to the back of it.if it hasnt been replaced by an automotive switch.Make sure, that if you have the proper ignition switch,that you dont have a ballast resistor in the line to the coil.you should also have a wire that runs from the starter solenoid to the ignition coil.it should run from the R term. on the solenoid to the + side of the coil.this wire sends 12 volts to the coil when starting,after that the voltage is reduced thru the ignition switch.if someone has added a ballast resistor,you wont get as hot a spark as you should have
perr
10-01-2003 06:48:16
 Re: Re: 3020 hard starter in reply to twopop, 09-30-2003 09:10:15
Thanks for the comments. I know that they replaced the starter switch, if the new switch does not have a resistor built in the back of it should a person put one in the line? Also, you mentioned a wire from the starter solenoid to the coil sending 12 volts. I bought a new coil and it is a 6 volt coil. Did they give me the wrong one, or is that 12 volts only sent for start up?
thanks
