720 Loose Wheel
OK-AL
09-29-2003 19:31:11
I've got a 720LP with the right side rear wheel that comes loose on the axle. (F 1500R) I've tried loosening the clamps and moving the wheel onto a different part of the axle, but it still moves after some time. (sometimes a few weeks, sometimes a few months.)
I've contacted a couple of salvages for some clamps, but they've said that they either don't have any or the cost is really high.
Can I put a shim inbetween the axle and clamp? I'm really tired of this problem and a little afraid that someday it will catch me off guard and fall off. Then i'll really be mad!!
Any help appreciated.
OK-AL
Jd Jack
09-30-2003 12:25:52
 Re: 720 Loose Wheel in reply to OK-AL, 09-29-2003 19:31:11
If you don't know the full history of the tractor(Have not owned it since it was new) I would be sure to check and make sure the right wedge is being used. I have a 3020 that did the same thing and it turns out that the origional wedge was broken by the origional owner, and replaced with a new one, but they didn't order the right one for that serial number. I tried all of the above suggestions w/o any help, then i ordered the new wedge that was correct and had no problems
Clooney
09-30-2003 09:02:12
Al, check the key for wear in the clamp & also the axle slot for wear..If that cast in key is worn that will allow the wheel to move every time the tractor changes direction & it will be next to impossible to keep it tight. ~Also make sure the jack bolts are backed out to the notch, if those are turned in too far you won�t be able to get the clamp tight..
MIKE HANLEY
09-29-2003 19:59:28
As long as the flange on the clamps are not bottomed out, flat up against the big casting. you problem not not need new clamps. We have had the same problem from time to time over the years. I can't do it, it take my son with a 3/4" brakerbar with a 3' pipe on the end of it. Ones I've tighten have to be retighted in a 1/2 day. Ones my son does have never come loose. Course it takes him to loosen them if we ever want to change the spaceing. If it has come loose more the once, put in new bolts and lock washers. When ever we have had the flanges out we coat them top and bottom with never-seaz.
ChuckW
09-29-2003 19:38:15
the wedges are probably not messing properly. This can be changed by grinding the stops on the inside of the wedge. When they are tightened evenly the wedges are supposed to be even.
OK-AL
09-30-2003 10:44:13
 Re: Re: 720 Loose Wheel in reply to ChuckW, 09-29-2003 19:38:15
The wedges are not even. I'll try to see if I can fix that.
I'm pretty certain that the wedges are up against the wheel, though.
I have the jack screws screwed out so that they're not touching the wedges.
Don't know about the key. I'll find out about that today.
Thanks to everyone for their help.
OK-AL
