420 T L
Thad
09-29-2003 15:32:30
Im not real good on JD tractors. What does the T L stand for after the 420. Thanks for help.
Wayne in Tn.
09-29-2003 18:56:09
 Re: 420 T L in reply to Thad, 09-29-2003 15:32:30
Thad, the T means tricycle configuration, but it can be a T with a wide front end. The L means it is an LP model (propane burner) I have one too and the tag reads 420 TL 131692. There were only 225 of the 420TL models built.
Thad
09-30-2003 04:06:07
 Re: Re: 420 T L in reply to Wayne in Tn., 09-29-2003 18:56:09
Thanks yes it is a LP has wide front with power steering. The tractor is taller than most has 34 inch rear tires is that normal. Thanks agin
Wayne in Tn.
09-30-2003 08:29:43
 Re: Re: Re: 420 T L in reply to Thad , 09-30-2003 04:06:07
Thad, that 34 inch is the common rear wheels on a T. The T will stand taller than a U or W. Usually the U and W will have 28 inch rears. However you will see some T's with 28 inch. Mine has the 28 inch spin outs on it.
