G rods
Rod
01-20-2004 14:23:49
Will the rods from a 70 JD fit a styled G? I would like to have the newer rods with the inserts if possible, my rods with babbit have some problems. Thanks
36 A
01-20-2004 19:37:13
 Re: G rods in reply to Rod, 01-20-2004 14:23:49
I just did this to my 47 GM last week and it worked great.70 gas rods and bearings,measure your crank it should be around 3.375 same as a G.I needed thicker bearings ,STD were loose.If you can use them ill give you a deal,there just sitting on the shelf.
Clooney
01-20-2004 14:54:10
Rod, having never done it myself all I can say is: the AF 1298R [F-1047R] 70 rod is the Deere called out replacement rod in the late G parts book.. So according to the book it should be a bolt in replacement..
[email protected]
