You need to check a few things: 1. What type of head gasket did they use and when the head was put on new, did it require a "crush" torque setting? 2. When the tractor warms up, that is an indicator of some flexure/worping somewhere. If I was you, keep an eye on the oil. If she is leaking water around the head gasket, it will try to work it's way around the cylinder and back down into the crankcase. 3. Do not worry about the valves as another person as indicated. It has nothing to do with this problem. Was the Head and the block checked to see if they were warped. If they have not, make sure to check them with a "Good" straight edge. If the head and/or the block is more than .003 (three thousandths) out of plane, the equals out to be a big problem. If the block was warped and the previous owner put the new head on there and torqued it down,(even with a new head gasket), now you will have both the head and the block that will need to be "decked". A person probably thinks that a gasket will take up .003 warpage. That is probably true. But remember, if it is warped on one plane, (on the block or the head), that is that much more distance that is needed to be took up down the line with the other cylinders. The head and block need to be co-plainer as close to true as possible! 4. The gas fired 3020 were natorious for stretching head bolts. The head was replaced for a reason. For about $12.00 a bolt, I would for sure replace the head bolts. Even harden head bolts have a moduls of elasticity. They are under torque and are subjected to constant vibrations and heat for "X" amount of years. You can do the math. 5. Finally, I would check the cylinders. Make for damn sure that the there is no cylinder play between the head and the counterbore of the block. This will be the first place that the water will go too. If or when you rebuild the upper end of the engine, use "Relience" brand of gaskets. Relience builds rebuild kits for John Deere. It is the same parts for half of the price. If the tractor still has this problem, and you still need to run the tractor, I would drain the antifreeze and replace it with water. If any antifreeze, (it does not take much), gets into the crankcase of the engine, that will fix her. On some of my old general purpose JD's, or any other of my antique tractors that have been sitting around or have not had a recent/consistant field work/overhauls, I will run water in them. If a "little" water gets into the crank case, that will not do as near the damage as anti-freeze will. If I am going to do alot of field work, then I will do an inframe or preventive overhaul if I see it is necessary. 6. These tractors are too expensive to replace and they are sought after. A little common sence will protect your investment. And thats what you have, a good sound investment.
