70D ignition/light switch
Jon Budde
09-29-2003 06:07:00
Does anyone know where I can find a new ignition/light switch for my 70d. I also need the fuel contact switch.
blksmok
09-30-2003 13:14:56
 Re: 70D ignition/light switch in reply to Jon Budde, 09-29-2003 06:07:00
Jon..... JD calls the "fuel contact switch" a rocker switch (??) It puts power to the fuel gauge from the battery when the diesel engine isn't running (Button depressed) and then power to the fuel gauge from the generator when the diesel engine is running (undepressed position). I have a couple used ones, as well as used main switches if you're interested.
F-I-T
09-29-2003 08:26:45
Jon:
Tyler gave you info on the light switch.
The dash panel mounted monentary push button switch that lets you power the fuel gauge while the engine is off is part number AF 2171 R. It lists for a little over $30 from Deere, but I'm not sure that it necessarily looks the same. Someone out there might have a servicable used one.
Here's the link to the switch as JDParts.com.
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
Link
Tyler-MO
09-29-2003 06:16:08
Jon,
The switch is af2460r and is available through JD for $59.00. I'm not sure as to what you are refering to as the "fuel contact switch". I hope this helps
Tyler in MO
