Difference in ROD BEARINGS between 520 and 50 JD??
Tyler-MO
09-28-2003 21:00:00
I still am searching for a way to get undersized bearings for my connecting rods on my 520. I see that undersized bearings are still in some dealer stocks for the model 50 LP. My question is what is the difference between the 50 and 520 bearings or crankshaft journals?? Thanks
Tyler in Missouri
Earl S.
09-29-2003 16:36:34
 Re: Difference in ROD BEARINGS between 520 and 50 in reply to Tyler-MO, 09-28-2003 21:00:00
Hi Tyler, 50 Deere Standard crankshaft rod journal is 2.749-2.750 Federal Mogul brg # is 2180 CP. 520 standard crankshaft rod journal is 2.874-2.875 Federal Mogul brg # is 2755CP. I don't think either is available from Federal Mogul. Check with Tom Underwood 316-684-3255 he might have some .Rebabbit old inserts Paul's Rod & Bearing Parkville, Mo. 816-587-4747. Earl
ChuckW
09-29-2003 04:45:02
didn't you have a crankshaft out of the 530 you bought? Do you still have it? Never heard from you.
Tyler-MO
09-29-2003 06:00:14
 Re: Re: Difference in ROD BEARINGS between 520 and in reply to ChuckW, 09-29-2003 04:45:02
Yes I do have a crankshaft out of the 530, the problems is that the area where the clutch pulley rides (bearing) is worn just as bad as my original 520 LP crank. I bought another crank and it is better than what I had. I wonder how "out of round" the journals can be and I will still get by? I can still get a set of .004 undersized bearings, I think?? I just don't want to take a chance and spin a bearing. Thanks for your advice
ChuckW
09-29-2003 04:29:23
journal size, 520 was beefier and had heavier parts, some of the parts diameters were larger, this is case of the journal...crankshaft heavier. Like I advised those oversize bearings are out there...if too much trouble go to another crankshaft....
