70g rear tread adjustment
Stu
09-28-2003 16:58:54
I am tinkering with my 70 Gass, General purpose, reaer tire tread adjustment. I am trying to set up a trailer plow, 2bottom IHC #8, (I will till earth this fall if it kills me), and its going to require me to narrow up my tread quite a bit. I got out the manual, and did all of the proper steps up to operate teh adjustable tread system. I was surprised that the three cap screws and the jack screws moved well. Of courcse, when it came to turning the adjusting bolt, the one that moves the wheel in and out... its totally stuck. I had a 24 breaker bar on it, and put about a 4 or 5 foot pipe on that to try and move it. Nothing.
I cant be the first to encounter this, and I look at the 70D, and 720D and they both look too like they havent been cracked in as many 30 years.
Any help to get this loose would be very appreciated.
Tim
09-30-2003 20:20:12
 Re: 70g rear tread adjustment in reply to Stu, 09-28-2003 16:58:54
Be sure you know whether it's the pinion that is frozen or the clamp wedge that isn't yet free. I don't have any further suggestions for fixing the problem but some apply to one problem and some to the other. If the clamp wedge is stuck the pinion will be stuck also.
Dan
09-29-2003 08:09:38
Stu, I just went through the same problem with my JD 50. When you get the wheel off the tractor as mentioned below, use a cold chisel and or air chisel on the pinion gear with lots of penetrating oil to get it to move. Once it moves even alittle you can work it with your wrench to free it up.
dennis cotton
09-29-2003 04:59:46
My dad's 60 was the same way. We took a pipe that was just barely larger than the axle, cut half of it away so that it would rest on the wedge and not the wheel casting. Then welded a endplate on it. Then proceded to beat the endplate with a sledge. It took about 15 good whacks and then it moved. I am personally lery of heating those wheel castings.
Larry806
09-28-2003 20:33:54
Believe it or not loosen the wheel you want to move. Than jack the other wheel off the ground. Take the biggest sledge you can find. Give the end of the axel 3 HARD wacks ( on the jacked side)That put's all the tractor weight on the stuck one when you jar it. I've seen this work when all else failed Larry
720Deere
09-28-2003 19:22:36
Clooney's method is about the best that I have found. I have done this with a few stubborn ones! One more thing to add, once you have the wheel off you can apply heat and take a punch about the size of the pinion shaft and drive it out. The shaft is made to punch out and sometimes it will break loose easier this way than with 250 lbs applied to a 6 ft cheater pipe.
Clooney
09-28-2003 18:35:31
Stu, I have encountered that same problem many times. The easiest way I have found to get that pinion loose is to pull the bolts from the inner clamp then turn the wheel so the pinion is on the bottom then work the wheel off the splines with the pinion just clear of the axle serrations. ~Once you have the wheel off you can use heat & penetrating oil on the pinion shaft to get it to turn. ~If you apply too much torque to that pinion without freeing it up you risk twisting the pinion shaft off.
