Removing behlen power steering
Bill R
09-28-2003 10:48:42
have a john deere a with add on behlen powersteering run from a pump on the distributor shaft. I would like to remove it and was wondering if there are any parts i need to mount that distributor back up to the tractor
thanks
Clooney
09-29-2003 11:06:12
 Re: Removing behlen power steering in reply to Bill R, 09-28-2003 10:48:42
Bill, you didn't give the tractor make or model but on most 2-cylinder Deere's there will be nothing needed. Just remove the pump & bolt the mag back up to the governor, then time the mag to snap as the L/H impulse on the flywheel lines up with the case mark [at 3 o'clock behind the flywheel]..
~What you will need is an intact steering shaft, or you will at least have to weld yours as it was probably cut to install the steering motor..
Bill R
09-29-2003 17:23:56
 Re: Re: Removing behlen power steering in reply to Clooney , 09-29-2003 11:06:12
Thanks clooney, it is a John Deere model A with distributor. I know about the steering shaft, i recently removed Char Lynn from a 60 john deere but it had its own pump up by the fan, and this one was different, i was just wondering, thanks again
