OUCH ....Water in oil J D ...A....
Bill Sandy
09-28-2003 07:41:32
Drained oil and it is milky. The guy I bought it from didn't have cans over the exhaust or intake. Could that possible be the cause or my worst fears,leaky head gaskit.Another question. Do I use gear oil in both the power lift and axle.This is a 1945 John Deere A
havvey
09-28-2003 16:10:03
 Re: OUCH ....Water in oil J D ...A.... in reply to Bill Sandy, 09-28-2003 07:41:32
some a's had brass tubes for the push rods in the head they were known to leak but not to difficult to put in improper manifold bolts would disrupt them
Will P
09-28-2003 20:11:38
 Re: Re: OUCH ....Water in oil J D ...A.... in reply to havvey, 09-28-2003 16:10:03
His 45A does not have those tubes.
Will P
43A
43B
49G
Dave K (FL)
09-28-2003 07:54:07
Water might come from a lot of places. I doubt if it would get in the oil from the rain through the exhaust, bit I am not certain. The most likely place is the head gasket, this is really not difficult to replace. After that I would suspect a cracked head or block. On the chance it got water from being outside, I would change the oil and keep a close eye on it to see if it gets water in it again. Also watch your radiator level to see if it is going down as the oil level comes up. It could just be condensation in there from sitting too. I have a 1948 A and it uses engine oil (non-detergent) in the lift and gear oil in the tranny and rear. I suspect any good hyd oil will work fine in the lift also.
Dave
Larry M
09-28-2003 08:59:33
 Re: Re: OUCH ....Water in oil J D ...A.... in reply to Dave K (FL), 09-28-2003 07:54:07
Bill, if the tractor has been setting outside in the rain I would check to see if rain has been leaking in around the clutch fork on the top of the reduction cover. I have a 1945 Model A and that is where water was getting into my crankcase. It took me two years and pulling the head 3 times before I finally figured it out. I would recommend you drain the oil from the crankcase, replace the drain plug (leave crankcase empty) and then take a garden hose and run water over the top of the crankcase including aroung the clutch fork. Shut the water off and then take out the drain plug and see if you get clear water. I first tried this with the drain plug out, but because of all the water running down the side of the engine you cannot tell if water is coming out of the crankcase drain or not. I think water leaking in around the cluch fork is a common problem with the old Deere's if left out in rain. Another problem area is the exhaust manifold gasket. I would check these two areas before I would tear into the engine, it might save you a lot of money.
Bill Sandy
09-28-2003 14:45:09
 Re: Re: Re: OUCH ....Water in oil J D ...A.... in reply to Larry M, 09-28-2003 08:59:33
Thanks Dave K in Fla.
Sounds like a winner. You made my day.....Bill...
In Mi.
Dave 1944 B
09-28-2003 16:17:58
 Re: Re: Re: Re: OUCH ....Water in oil J D ...A.... in reply to Bill Sandy, 09-28-2003 14:45:09
I had water in my oil recently. I traced it back to the push rod passage inserts in the head. It took me two months, and had the head off three times before finding it. I bought new ones at John Deere and had a machine shop install them. Good Luck,
Dave
Will P
09-28-2003 20:10:37
 Re: Re: Re: Re: Re: OUCH ....Water in oil J D ...A in reply to Dave 1944 B, 09-28-2003 16:17:58
While true, that push rod tubes leak. But his 45A does not have those tubes. So he can rule that out.
Will P
43A
43B
49G
BJ
09-28-2003 07:51:29
I guess you could just leave the oil drained out of it for a couple of days and put the drain plug back in and see if any water accumulates (obviously make sure nobody starts it while you are doing this) and also take the oil cleaner cup off and get the water and crud cleaned out of it. The power lift and rearend are different reservoirs gear oil in the rear end and for the lift 20 wt. hyd oil is my choice
