diesel fuel in crankcase
bill c
01-20-2004 13:39:49
hi. while my john deere 300b was idoling I heard a loud snap in the engine and it quit. Now I have diesel fuel in the crankcase. Any suggestions. thanks
Bob
01-20-2004 19:32:34
 Re: diesel fuel in crankcase in reply to bill c, 01-20-2004 13:39:49
Is the engine seized, or will it turn over?
If it will turn over, be sure the fuel tank shutoff valve is closed, and drain the diluted oil out and replace it with fresh oil before cranking the engine over for any further testing.
If the engine is not stuck, my guess is that the "hydraulic head" in the injection pump seized.
The diesel injection pump driveshaft has an area of reduced diameter, where it is designed to break, if the pump seizes. This prevents destruction of the timing gears.
The injection pump shaft seals are right next to the area where the shaft is designed to break, so that could explain the diesel fuel leaking into the crankcase.
If the engine turns over, take the timing cover plate off the injection pump, and verify that the pump is not turning before removing it for repair.
bill c
01-22-2004 05:19:58
 Re: Re: diesel fuel in crankcase in reply to Bob, 01-20-2004 19:32:34
engine is seized up. Is it possible to rebuilt or should I look for rebuilt engine?
old
01-20-2004 13:44:13
Its probably caused by a bad shaft seal in the injector pump, and the snap was the engine sezing up
bill c
01-22-2004 07:06:30
 Re: Re: diesel fuel in crankcase in reply to old, 01-20-2004 13:44:13
old
01-22-2004 07:43:02
 Re: Re: Re: diesel fuel in crankcase in reply to bill c, 01-22-2004 07:06:30
Well I had the same thing happen to me on an Allis 190XT, and what I did was fill the cylinders with turpentine and let it sit a day or 2 like that and then I tried to turn it over and it turned. Of course I did change the oil and replaced the seals in the pump, as a matter of fact I had the pump rebuilt. But any how that is all I had to do to have a good running tractor again. I used it to bale with last year and it didn't smoke and purred like a kitten. If your lucky you may get by that way
