820 Black Dash Pony Motor
Mark F.
09-27-2003 20:11:14
My pony runs great sometimes, and is very hard to start at other times. Have messed with carburetor and points quite a bit. Carb seems ok, but when points are set to run well, it won't start. If I set them so it will start, it has virtually no power. Help??
F-I-T
09-27-2003 20:22:23
 Re: 820 Black Dash Pony Motor in reply to Mark F., 09-27-2003 20:11:14
Mark:
You say "set the points so it will run well"...
Are you changing the point gap to try and affect dwell and timing?
Have you set the timing? I've seen some pony's that timning doesn't seem to affect much, and others that it makes quite a bit of difference.
To time, set points correctly, find the timing mark (flywheel side under the tin cover) and use a screwdriver to set the engine dead on #1 spark TDC, roll distributor all the way forward, turn on ignition, roll distributor toward rear until spark occurs, and you're done! Don't let the ignition on for too long or you might burn out one or boh pony coils.
If you have atiming light it makes it even easier and probably more exact.
Frank-in-Tallahassee
70D // 855 // VAC
