Checking valves on a GM ( G)
mike
09-26-2003 17:05:03
I started working on my GM today. How do you check the valves on this tractor? Is the valve cover the heavy looking cast piece in the front of the engine? looks like two nuts hold it on the engine.What steps do i take to remove this cover?
Thanks Mike
Thanks for the help on the D
easydoesit
09-27-2003 03:52:02
 Re: Checking valves on a GM ( G) in reply to mike, 09-26-2003 17:05:03
mike, yes,you have to remove the two nuts that hold the valve cover on. You may have to prize it off and will likely mess up the cork gasket if it has been on there awhile. You will likely need another gasket. The next problem is that you can't remove the cover w/o removing at least the carb bowl. You can't put alot of torque on the bowl nut w/o breaking the stem off the bottom of the carb so I typically remove the carb. I do recommend the repair manual for the A,B,D,G,& H tractors. Easy
