John Deere H radiator fan
Arnie
09-26-2003 14:49:16
I have a H with a broken fan blades. Can the fan be taken off the shaft and replaced with new one or do I have to take hood, gas tank and radiator out to do this job? thanks for any and all help. I have received some info because i posted on the wrong site hope this one is right site thank a million for any help given Arnie
Paul from MI
09-26-2003 20:24:06
 Re: John Deere H radiator fan in reply to Arnie, 09-26-2003 14:49:16
You do not have to remove the sheet metal & the radiator to get the fanshaft off. Remove the carb & the elbow to the air cleaner. You may have to remove the sediment bowl & fuel valve also. Then remove the governor & fanshaft as a unit. When reinstalling, turn the flywheel to L.H. Impulse, set slot in governor shaft horizontal & re-install to get mag timed right. Fan should be replaced unless you are really sure of a good repair of fan. Fan blades taking off at about 387MPH are dangerous to say the least.
Paul
