JD 332 Lawn Tractor Serial # info missing/needed
Henry
09-26-2003 14:43:33
I recently bought a JD 332 from a local dealer. There is no serial number or model # plate anywhere on the tractor. He said he couldn't find it either & JD will not tell them where else it may be found. I called to order a manual and the first thing they asked was for the serial number. Someone said that JD also stamped those numbers on it somewhere else. Any ideas or thoughts???
billde
05-16-2006 04:53:06
 Re: '40 B oils in reply to van robinson, 05-15-2006 22:36:04
There is a chance of foaming when detergent oil is used in hyd systems. Use either non det motor oil or hyd oil in the lift system. I use 15-40 in the engines of my old JD's.
Joe M (GA)
09-26-2003 14:59:15
 Re: JD 332 Lawn Tractor Serial # info missing/need in reply to Henry, 09-26-2003 14:43:33
There were very few changes through the 332's short run, most had to do with the air cleaner, seat, and some controls
332 LAWN AND GARDEN TRACTOR
1987 MODEL (SERIAL NO. M00332X420001-475000) 1988 MODEL (SERIAL NO. M00332X475001-595000) 1989 MODEL (SERIAL NO. M00332X595001-999000) 1990 MODEL (SERIAL NO. M00332X010001-100000) 1991 MODEL (SERIAL NO. M00332X100001-110000) 1992 MODEL (SERIAL NO. M00332X110001- )
NOTE: THE ENDING MODEL SERIAL NUMBER " -999000" FOR 1989 IS HIGHER THAN THE BEGINNING MODEL SERIAL NUMBER "010001- " FOR 1990.
