 Mark, T213R pretty well gave you what you need to know.. Just a little follow up.. ~For the rockshaft to operate the rear P/T plugs MUST have open fronts ,, for any remote cylinder to operate the P/T plugs must have open rears [or the side P/T ports must be used] & SHOULD have closed fronts or the rockshaft will move at the same time as the remote is operated..[see picture].. If the top port has an open front the remote cylinder will only work as a one way cylinder. ~There are ways around the problem [somewhat] .. Probably the best is to install a selector valve [or valves] in the remote outlets then plumb your loader into the side pipe plug ports on the R/H side of your P/T valve box.. That way all you have to do is remove the cap [or caps] & open or close the internal valve(s) to either open or close the front ports & use the rockshaft or remote cylinder [not at the same time though].. A single selector valve works fine for one way remote cylinders.. To get two way remotes takes creativity or two selectors.. ~The other way is to install a single selector valve in the top port & leave the open front plug in the bottom then plumb one remote hose to the top side P/T outlet & the other remote to the lower P/T side outlet, then either let the rock shaft raise as the remote works or chain the rockshaft [3-point] down so it can't lift as the remote is operated.. OR, close the P/T throttle valve & let the rockshaft raise up during the first remote usage & the closed throttle valve should hold it there.. ~Probably the absolute best way is to look for a live hydraulic pump that bolts between the mag & governor so you can not only have live hydraulic power but also cut into the pressure supply line & install an open center hydraulic control valve for the loader & that allows the 3-point to operate at the same time [well not at EXACTLY the same time but either one without any additional valves to be moved] ~I know this probably is as confusing as it is helpful so E-Mail or post any follow up questions... [email protected]
