630 Charging Problem
Scott
09-26-2003 10:48:46
I have a 630 that is not charging. Generator has been tested and regulator replaced and polarized. Not sure the regulator is wired correctly although it matches the ITT Manual. Noticed in my 60 manual that it is wired completely different. Amp gauge shows discharge but never charging. Can anybody give me some help or possibly have a schematic?
Clooney
09-26-2003 18:23:32
 Re: 630 Charging Problem in reply to Scott, 09-26-2003 10:48:46
Scott, you are correct, the 630 is wired different than the 60....
~It is pretty easy to check out though.
~~~~~~~~~~~~~Lets start at the generator~~~~~~~~~~~
--The generator's [A] post hooks to the regulators [Gen] terminal [that could be a wire or terminal running from the bottom of the regulator or just a side terminal, they should be marked].
--The generator's [F] post hooks to the regulator's [Fld] terminal.
--The regulator's remaining terminal [Bat] terminal is hooked to the ammeter's NON BATTERY POST with a white wire.
--The regulator's base MUST be bolted to the generator, or at least fully grounded to either the generator or tractor chassis.
~~~~~~~~~~~~~Now on you problem~~~~~~~~
~First,, make darn sure you have battery power to the [BAT] terminal on the regulator [it won't ever charge if you don't]. Then make sure the wire feeding that regulator's [BAT] terminal is hooked to the NON BATTERY SIDE OF THE AMMETER [my guess is that's your problem].
~If all the above is good you should polarize the generator [that could also be your problem]..To do that... ground the generator's [F] post to the generator's frame, then momentarily jump battery power from the regulators [BAT] terminal to the generator's [A] post, you should see a spark & if so remove the jumper wire & [F] post ground as it is then polarized.
~If it still won't charge do John's generator test below.
~I do have a specific wire diagram for your 630 but it isn't in an E-mailable form. The above wire description should be enough for you to wire it correctly,, if it isn't, give me an E-Mail & I will convert it to digital & send it to you [I'm not near my shop computer & that computer is off so I can't access it at the moment].
~Let us know what you find?
[email protected]
John T
09-26-2003 15:05:38
Scott, first of all, is the new regulator a 3 wire (BAT, ARM, FLD) or a 4 wire (BAT, ARM, FLD, LOAD) and is it the same as the old one was????? Regardless which type the new one is or the old one or if it was modified, (3 or 4 wire), if it and the generator are both okay, I can tell you how to wire it to make it work.
Here are a few questions that will help me help you.
Is the tractor still original positive ground??? Is the new regulator suitable for the ground you have??? some are okay pos or neg ground, others are not. Once all was wired up, did you polarize by momentarily flash jumpming a wire from the VR's BAT terminal over to its ARM terminal and did you get a spark???? Are you sure the generator is well grounded and the VR is well grounded (usually to the generators case) ????? Is there battery voltage present on the VR's BAT terminal all the time??? It has to be cuz thats where the gens output gets its connection to the battery to charge it. Does the ammeter ALWAYS show a discharge, or only when the ignition is on???? If you have the tractor off and turn on the lights, does the ammeter swing to discharge???
******************3 WIRE VR WIRING**************
The BAT terminal is wired to the load (non battery) side of the ammeter.
The ARM (or GEN) terminal is wired to the armature (larger of the 2) posts on the generator.
The FLD terminal on the VR is wired to the Field post (smaller of the 2) on the generator.
On 3 wire VR systems, loads like lights and ignition are fed from the load side of the ammeter where the VR's BAT terminal is also wired. On 4 wire VR's which have the extra 4th LOAD terminal, loads like lights and igniton are wired to it instead of the ammeters load side.
************** 4 WIRE VR WIRING*****************
The BAT terminal is still wired to the load (non battery) side of the ammeter.
The ARM (or GEN) terminal is still wired to the armature (larger of the 2) posts on the generator. On many 4 wire VR's, its off on one side by itself or on the bottom by itself.
The FLD terminal on the VR is still wired to the Field post (smaller of the 2) on the generator.
The extra 4th LOAD terminal is where the lights and ignition get their power instead of off the ammeters load terminal as on a 3 wire VR system.
TO MAKE AN OLD 3 WIRE SYSTEM WORK ON A 4 WIRE VR
1) You could leave all as above or as it was and let the loads like lights and ignition remain on the ammeters load terminal where the VR's BAT is wired to and not use the LOAD terminal.
OR
2) If you want to use the LOAD terminal on the VR, wire the light and ignition switch to the LOAD terminal and not to the ammeters load side. (wire down to BAT on VR remains on ammeters load side however)
TO MAKE AN OLD 4 WIRE SYSTEM WORK ON A 3 WIRE VR
The light and ignition and switch wire(s) that used to go to the LOAD terminal on a 4 wire VR would have to be wired instead to the load side of the ammeter where the wire to the BAT terminal on the VR is wired.
***************TROUBLESHOOTING*****************
Since the generator was tested and the regulator replaced, assuming they are BOTH good and polarized properly, I first suspect its wired wrong or the gen or VR are not well grounded or theres a short in the wiring. I suggest you check the wirign per my above directions, insure the BAT terminal is always hot, determine if the old and new systems are 3 or 4 wire, re polarize, see what the ammeter does on and off and when lights are turned on and post back your findings.
I will go ahead and post my standard tests to see if its a generator or a voltage regulator problem for your future reference just to be safe, but look at the wirign and check the grounds and for shorts etc. first, since the gen was already tested and the VR is new. I can try to e mail you a 630 wirign diagram, post back if you want me to.
********GEN VERSUS VR TROUBLESHOOTING***********
1) First, be sure the belt is good and tight and the generator has a good ground to the tractors frame and that the VR has a good ground to the generator. Many problems are caused by a bad ground to the generator or the VR is not well grounded (usually to the gens case). You might run a wire direct from the batterys grounded terminal down to the gen and VR and and connect it to see if thats the problem.
2) There has to be hot full battery voltage present on the VR's BAT terminal so its output can get to and charge the battery. (Use a test lamp or voltmeter to insure that before you go on) The HOT path to get there, is from the battery itself or off the starter post, to and through the ammeter, then down to BAT on the VR.
3) Now if the grounds are good and the VR's BAT terminal is hot, you can finally test the gen and VR to determine which or both are bad. With the tractor running, use a jumper wire and connect the F post out of the generator (smaller of the 2 gen posts) to the generators steel frame ground, and if the ammeter then shows charge, you either have a bad VR or a bad/broken wire connection between the generators F post and the F terminal on the VR.
4) If she still doesnt show charge, leave the F grounded, and then momentarily connect the BAT and ARM (or GEN) on the VR together to see if it shows charge. If she charges then, you have a bad cutout relay inside the VR. If it shows charge only if you connect the VR's BAT terminal direct down to the gens ARM post, the wire is bad (open) between the gens ARM post and the VR's ARM terminal.
5) With the F still grounded and the GEN or ARM on the VR connected to the BAT terminal and if the Gen and VR have good grounds and assuming the BAT terminal is connected to the battery via the ammeter and she still dont charge, its probably a bad generator, cuz you have essentially by passed any bad VR with the tests above.
6) You can also motor test the gen by removing its belt and all its wiring (protect all the wiring so it doesnt short out) and jump wiring the ungrounded bat terminal (i.e. - on a + ground system) to the generators ARM post (larger of 2) and the generator should turn like a motor. A source of such battery power could be the wire from the VR's BAT terminal, as it leads to the battery via the ammeter. If it runs when you do that, then ground out the generators F post and she should slow down slightly. If not, the gens field may be bad. If the gen turns when you apply battery voltage (from the BAT lead or elsewhere) and slows slightly if you ground out the F post, it should generate power fine.
Post back or e mail [email protected] me or call me 812-824-4608 with your findings and for any more help.
Good Luck and God Bless
John T Nordhoff in Indiana
Scott
09-30-2003 11:34:21
 Re: Re: 630 Charging Problem in reply to John T, 09-26-2003 15:05:38
Clooney & John T.
Thanks to you both for the advice. Here is where I am at with this thing.
1. Regulator is a three wire type, same as the old one. Good for pos or neg ground.
2. Tractor is still pos ground.
3. Regulator is wired correctly.
4. Good voltage to regulator.
5. Good ground on generator.
6. Polarized and got a spark.
7. Ampmeter shows discharge when ignition is on or ignition off and lights on.
8. Generator is charging according to hand held meter, but doesn't show charge on ampmeter.
9. Installed a new ampmeter but didn't get to check it because starter solenoid went out. New one comes in today.
10. Charging wire from ampmeter is hooked to the starter solenoid on the battery cable side (negative battery post).
I did change the ignition/lights wire from the battery side of the ampmeter to the regulator side. Haven't got to try it since.
Any more suggestions are sure welcome.
Scott
