1020 injector pump check valve clogging
Montpelier
09-26-2003 10:32:04
Have experienced problems with the recirculation check valve on the fuel injection pump clogging on my 1020. Have replaced filter and cleaned lines down stream of the filter element. It looks like depris is comming from the pump. Would appreciate any suggestions such as a good fuel treatment that will be effective in removing the gunk.
Matthew
09-26-2003 21:44:53
 Re: 1020 injector pump check valve clogging in reply to Montpelier, 09-26-2003 10:32:04
I had my diesel injection pump completely rebuilt for my 1020 about 2 years ago by Diesel Injection of Cary, NC. They did a great job, know this type of pump inside and out, and did the whole rebuild plus sent me 3 new injectors for about $450.
I don't know exactly about the problem you are having, but I'm sure they can help. They can hook it up to their test equipment and diagnose quickly.
They're website is down right now, but here's their contact info:
Bob
09-26-2003 16:41:55
There is a clear plastic ring in the governor of the pump that turns to black crumbly crap after too many years of heat and diesel fuel. If you keep running it, and cleaning the housing pressure regulator valve, you will eventually get rid of all the black crap, the only problem is that by then metal pins will be banging into the ends of metal slots, and instead of plastic crap you will have metal filings!
The fix is to replace the governor weight retainer with an improved version that will not come apart later!
This part costs about $45.00, plus a $35.00 "O" ring and seal kit for the pump, but by the time a diesel shop gets done with it and runs the pump on a test stand, the whole deal will cost you $250.00 to $600.00!
A knowledgeable person can replace the problem part with 1 or 2 hours labor, and if you are carefull, and don't mess with anything else, the calibration of the pump will not be changed.
Brokenwrench
09-26-2003 11:21:37
No additive is going to help it.The pump needs to be removed and rebuilt as it is starting to come apart inside.
