Empty stalls in the barn where the horses belong
MIKE HANLEY
09-25-2003 22:25:14
This thing could have all kinds of subtitles. Like "can't complain The guys dead", or "they were PRO"S?", or "they ain't there anymore".
Those of you that have been following the missing horses in the 730D's. For this post I'll just stick to our main 730D.
Brief history: Had some questions about pump pressure on a 730D. Then checked out our Main 730 as that would pull the baler a gear lower then the back up 730D even thougth the main 730D had a complete $5,000 engine overhall 1200 hrs ago.
Well I sent the main 730D to the JD dealer at Westby and told them lets find out why. It DINOed at 40HP.
Here's what has been found out so far. The hole where the pistion in the primary pump sets was wore out as was the faceings. Had that machined The rack was a mess, and the injector tips were shot. Had them rebuilt. That done, pump pressure went from 4# to 42#. Still DINOed at 40HP.
Pulled the engine apart. Cylinders out of round. Wrist pins wore out. Valves so far into the head it was hard to belive. One push rod bent and one push rod twisted. Thrust washers on chank GONE.
Now here's the corker. The JOHN DEERE dealer that overhalled that Tractor has been bought out and the old owner long gone. The macanic that did the work died of old age. The machine shop that did all the machine work is no longer doing machine work. Just selling parts. The diesel shop that did the pump and injector work is still there. The JOHN DEERE dealer that has the 730D now has had a lot of trouble with both that machine shop and that diesel shop and hasn't used them in years. THIS TIME WE WILL FIX IT RIGHT.
Now here is an intresting point,,,,,Suppose I sold that tractor and got big bucks for it and presented the new owner with all the shop bills from that 1st overhall, bragging that the engine only had 1200 hrs on it from a JOHN DEERE dealer not knowing what I know now..... And then the new owner find out what I just found out. Then what???
We were going to overhhaul the back up 730D next year as we know no history of that engine. Now that will have to wait for the check book to cool down.
Bob-Wyo
09-26-2003 11:57:38
 Re: Empty stalls in the barn where the horses belo in reply to MIKE HANLEY, 09-25-2003 22:25:14
Hey Mike sounds like my buddies A, you could hand crank it till the water boiled and still no start, but pull it 5 feet and away it would go. When we pulled it down we found some one bored it out to 45 over and put standard rings and the old standerd pistons back in it.
Sorry to hear about your problems, hope all works out in the end for the best.
Bob
Mike
09-26-2003 11:44:30
A lot can happen in 1200 hrs. How long has it been since the work was done. If you paid the bill, I think the tractor didn't run like a 530 when you got it back.Its possible that the dealer messed it up, but also in 1200 hrs, and how ever long its been, alot can happen. All it takes is a bad batch of fuel(dirty, water,algae) to trash a set of nozzels and or pump.The fuel nowadays does not have the lubricity that it had years ago, hammered valve seats are a very common occurance now unless hardened seats were installed.A trip down a hill with a loaded wagon behind it and some overspeeding can bend push rods, spin out bearings. If the tractor sits alot and is started, the wristpins are run dry until oil gets up to lube them(wristpin wear).If the 1200 hrs were put on the tractor in a year or less,I would say you had grounds to complain, but if its been 3-4 years, some of the blame falls on the owner/operator.
Blksmok
09-26-2003 05:57:13
Mike..... ...what's your guess as to why the mechanical condition "is what it is" after only 1200 hours???
MIKE HANLEY
09-26-2003 06:29:05
 Re: Re: Empty stalls in the barn where the horses in reply to Blksmok, 09-26-2003 05:57:13
What they tell me so far is that it was poor workmanship both with the pump work and the machineineing that was done 1200 hrs ago. That is why this JOHN DEERE dearler hasn't just those shops in years while the other dealer that is no longer there still used those shops for there outside work.
MIKE HANLEY
09-26-2003 08:46:40
 Re: Re: Re: Empty stalls in the barn where the hor in reply to MIKE HANLEY, 09-26-2003 06:29:05
Just came from Westby. Went down to help them pull the Dengler LOC-TITE flywheel. As per the written instructions, 3 hits with a 16# maul and it poped right off. The pistons are JOHN DEERE .090 over and are perfect. It's the wrist pins that are wore. The Valves look like they came out of the box yesterday. The valve seats are gone as are the valve guides. The valve springs are very weak. The only way the cylinders could be out of round without any wear on the pistons must be just a poor bore job. Or it wasn't bored out like it was suppose to be. As to the head, nothing new could have been put in. The seats must have just been honed and the old valve springs put back in.
Mike M
09-26-2003 12:21:52
 Re: Re: Re: Re: Empty stalls in the barn where the in reply to MIKE HANLEY, 09-26-2003 08:46:40
You say JOHN DEERE .090 over pistons ???? Last time I looked in my parts book only .045 offered and these should have the keystone style {tapered like a wedge } piston rings on the top groove to seal better. The .090 and .125 were from aftermarket co. My cousins 720D had .090 or .125 over pistons in it can't remember for sure now but the previous installer used what must have been standard size oil rings tractor ran good but used lots of oil. Hope you can find a good mechanic this time I have seen a lot of poor rebuilt ? tractors and some were from the big name local JD dealer.
Dr.EVIL
09-27-2003 20:19:05
 Re: Re: Re: Re: Re: Empty stalls in the barn where in reply to Mike M, 09-26-2003 12:21:52
Sounds like You had some work done at the same Deere Shop My Dad used to use. Kid there bragged He was the Best Danged Deere mechanic in the Midwest! He was a Real Ledgend in His OWN MIND He was! He screwed the first tractor up, an R so bad Dad sold it, and rebuilt the 4010's injection pump with used parts!
