JD 60 rocker-arm oiling
Bob
09-25-2003 21:49:00
Is it normal oiling for the intake rockers to run on the dry side as compared to the exhaust rockers.
Clooney
09-26-2003 03:00:15
 Re: JD 60 rocker-arm oiling in reply to Bob, 09-25-2003 21:49:00
Bob, that's normal, the old Deere 2-cylinders don't use valve seals & have rather large valve stems, so if the oil is sprayed [or dripped] directly on the intake valve stems they tend to suck oil into the combustion process & burn oil. If the engine RPM's are kept up [where they were designed to be run] & none of those super stick oil additives like Lucas are used, the valves will oil just fine with the oil mist in the rocker cover area.
Lee
09-26-2003 01:50:00
I assume yes, as I only have letter number series but they only have oil holes to drip oil on the exhaust rockers. The intake rockers oil from mist or the occasional flipped off drip from an exhaust rocker. If you drill some drip holes for the intake rockers you just wind up with a smoking oil burner for a tractor - there should be some middle ground in there some where, if you figure a way - post it, I'm interested.
Bob
09-26-2003 15:24:39
 Re: Re: JD 60 rocker-arm oiling in reply to Lee, 09-26-2003 01:50:00
Lee, thanks for the response and you would be the third person that says the oiling works that way. And with the 60 running and running and running for 50 years it must be ok.
Thanks, Bob
